warrenp Posted January 27, 2004 Share Posted January 27, 2004 ohh i'm confused! i just bought a t5 world class transmission from a mustang i wanna bolt it to a chevy engine but the bellhousing from a chevy t5 will not bolt up. i tried one that came on a TA 2.8 i realize the 2.8 will not fit a v8 engine i just wanted to see if the bell housing would bolt up and it does not. the t5 that it was bolt to was not a world class would that make a differance? any way i need a bell housing that i can bolt my T5 world class number 208 to a chevy 250 engine same bolt pattern as a v8 what can i get one from? what years work? how much should i spend? Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted January 28, 2004 Share Posted January 28, 2004 I remember someone here - I want to say Mike C - about a bellhousing available that allows a mustang T5 to be used in a sbc. I can't remember if you needed to change the input shaft or not. Do a search, the post is out there somewhere. Good luck Quote Link to comment Share on other sites More sharing options...
labrat Posted January 28, 2004 Share Posted January 28, 2004 You'll definitely need to change the imput shaft, as the spines are incorrect for a chevy clutch. Other than that, i'm not sure about he bellhousing. I think lakewood or someone makes one, but a simple adapter plate may be your best bet, dollar wise. Quote Link to comment Share on other sites More sharing options...
warrenp Posted January 28, 2004 Author Share Posted January 28, 2004 i'm just going to run a fod clutch. summit offers a bell housing that adapts the ford T5 to a chevy v8 FOR $319 i would rather use an adpter to cut down on cost if i can find one. hey heavy z, thats a nice z i like how that scoop was added over the stock cowl. Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted January 29, 2004 Share Posted January 29, 2004 Thanks Warren, good luck with the swap. If you are able to get the ford setup working you'll save money in the long run should you ever need another T5 since fords are cheaper. Quote Link to comment Share on other sites More sharing options...
wheelman Posted January 29, 2004 Share Posted January 29, 2004 I asked a similar question a while ago and someone mentioned that a bell housing from a 96 Camaro with a V6 would work. It was stated that the bolt pattern for the engine side was the same as the V8 and the tranny side was the same as a Ford T5. I never did really check this out because not to long after that I ran across a good deal on a GM WC T5. Good luck with this and let us know what you find out. It would be great to find a relatively cheap way to adapt a Ford T5 to an SBC as the Ford trannies are very easy to come by and the GM units aren't, at least not where I live. Ken W. Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 29, 2004 Share Posted January 29, 2004 The Buick 3.8 or 3800 bellhousing if a BOP (Buick Olds Pontiac) pattern and will not bolt up to the Chevy. If I was buying all new parts, the brand spankin' new Ford Motorsport T5 and the Lakewood bellhousing is the way to go. For $1500 you have a brand new trans and explosion proof bellhousing. What you will find with adapters is that they are also very expensive. You can check with TransDapt or Advance Adapters about availability for the one you want. But IMO, the steel bellhousing is a no brainer in an ultra high performance vehicle. Quote Link to comment Share on other sites More sharing options...
warrenp Posted January 29, 2004 Author Share Posted January 29, 2004 bucik,pontiac, olds made a standard bell housing that will work also on ebay there is an adapter to bolt a olds bolt pattern to a chevy engine for $20 i bet i can do that set up for less than $100 to make it work. Quote Link to comment Share on other sites More sharing options...
Trevor Posted January 29, 2004 Share Posted January 29, 2004 Here is a 1997 Camaro V6 (I'm guessing a 3.4L??) Bellhousing. It has a Ford B&W T-5 transmission bolt pattern and BOP 90-deg engine bolt pattern. The length of the input shaft for the Camaro V6 T-5 trans is 182.1mm, the Ford T-5 trans input shaft is very close at 182.6mm. If you added any more spacers between the engine block and trans, I don't know if the input shaft whould reach to the pilot bearing. One option is the Mustang 3.8L V6 T-5. It has a longer input shaft at 199.9mm. Gives you about 5/8" more reach. Quote Link to comment Share on other sites More sharing options...
Heavy Z Posted January 30, 2004 Share Posted January 30, 2004 Hey Mike, those motorsport T5's don't happen to have a counter gear stabilizer like the one at gearzone already built in, do they? Quote Link to comment Share on other sites More sharing options...
Mike C Posted February 3, 2004 Share Posted February 3, 2004 I don't know the answer to that. Jeg's catalog describes it as having a Cobra style pocket bearing and a steel input bearing retainer. Quote Link to comment Share on other sites More sharing options...
Trevor Posted April 7, 2004 Share Posted April 7, 2004 Just stumbled across this trivia. May be a wrecking yard part solution. If I read this right according to Jeep engine swap sites: Quote T-5 from a Mustang will fit any AMC engine if you get the bellhousing from SR-4 ('76-'81), T-4 ('82-'88) or T-5 ('83-'88), and the throw out arm and bearing, from the same bell. Also the front bearing retainer is needed, gm size, (maybe gm part?), if you don't want to modify the Mustang part. Right clutch disc with the correct # of splines that also fits the pressure plate you're using, and the pilot bearing is also needed. found it here http://www.bit.spt.fi/antti-ville.nauha/tech/amc_manual_trannies.html Quote The 151 (2.5L) inline 4 engine was used in '80-'83 CJs including the CJ-8, CJ-7, and CJ-5. The 151 is often called the "Iron Duke... The engine does have the Chevy bell housing bolt pattern though. The engine is manufactured by GM and uses a cast iron block .... The neat part about the engine is it has the same bell housing bolt pattern as a Chevy small block. The bell housing makes a great low buck Ford/Jeep to Chevy adapter since it is basically Ford on the transmission side and Chevy on the engine side. A regular Chevy bell housing will bolt to the 151, . Also, a Chevy 305 or 350 will bolt right to the Iron duke bell housing. Found it here http://www.jeeptech.com/engine/gm151.html The jeep also uses a hydraulic clutch! Quote Link to comment Share on other sites More sharing options...
dot Posted April 7, 2004 Share Posted April 7, 2004 More trivia: The clutch master for the Jeep is the same part as the 1st gen Z. The hydraulic through out bearing for the 4.0L Jeep won’t fit anything else. I tried... and still have it. Both parts are pricy. Quote Link to comment Share on other sites More sharing options...
TJOL Posted September 14, 2009 Share Posted September 14, 2009 Sorry to revive such an old thread but I've been doing some researching into V8 swaps and wanted some clarification on the use of the mustang T-5 WC with a Jeep T-5 bellhousing being used to adapt it to the SBC bolt pattern. If I understand this correctly the Jeep T-5 bellhousing bolts to the mustang T5 on the transmission side and has the Chevy bolt pattern on the engine side. So my question is what else needs to be done to make this work properly? New input shaft? Different pilot bearing? Thanks for the help in advance. Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 14, 2009 Share Posted September 14, 2009 Here's some pictures of the forementioned bellhousing: http://cgi.ebay.com/ebaymotors/Jeep-CJ-Bellhousing-Small-Block-Chevy-Swap-76-86-t5-t-5_W0QQitemZ220480574435QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3355aa93e3&_trksid=p4506.c0.m245 The input shaft for a WC T5 Mustang is 9-1/4", very close to the input shaft length of the NWC T5 Jeep trans @ 9-5/16" You shouldn't need to change the input shaft. Might need to mix some clutch parts, I don't know if Chevy clutches are for 1-1/8". You might need to Use either a Jeep or Mustang clutch disc, (both are 1-1/8" 10-spline). That fits within the desired chevy clutch pressure plate. For the pilot bearing, Ford T5s have 2 pilot diameters: 2.3 4 cyl. and V8, the small pilot dia. is 0.590" (the same as Chevy V8 and V6.) the large one is 0.668", this is a custom bearing, but available from hotrod parts sellers like Speedway and Summit. Quote Link to comment Share on other sites More sharing options...
