URGENT! 280ZX -> 260Z mounts
drunkenmaster
Hi all,
I need to know whether the 280ZX and 260Z/240Z share the same engine mounts and gearbox/crossmember mounts.
I am having custom engine mounts made and gearbox crossmember made to suit an RB motor BUT the builder accidently got in a 280ZX dummy car for my 260Z.
Please let me know ASAP if this will work if you can
Thanks
The tranny mount is different, IIRC. The Z has basically a flat bar which attaches on either side of the floorpan straddling the tranny tunnel. IIRC, the ZX has a much shorter crossmember which hooks into to brackets up inside the tunnel.
Or have I killed too many brain cells since I was last under a ZX???
Jon
Well I think the actual rubber engine mounts are the same for the engine, but not the tranny. But I asked if I was remembering correctly because it has been 5 years or so since I've pulled a tranny from a ZX. I think I'm right because I remember it being much easier than a Z...
Jon
