Which 280ZX Master Cylinder?
Be aware that going to the larger 15/16" m.c. will increase the effort required at the pedal for a given level of braking by 15%. I put the 7/8" MC back in my car, I could feel the firewall flex under the pedal effort required at the track with the ZX m.c. I do have smallish (stock z and ZX) brakes, though.
The early MC is a bolt on for all S30-series cars. But you may find that the lines are reversed. You should correct this by bending your tubing to suit.
Another thing worth mentioning is that you may need to swap residual valves over from your old MC to the new one, as the 280ZX is a 4-wheel disc setup.
For those who want a 1" MC I used JB1419 from a Nissan Patrol - lines reversed, valves removed, it firmed up my pedal just nicely with my LN65 Hilux/ R31 Skyline brake setup (soon to be R33 Skyline/R31 Skyline).
