Whats the best oil for me?
Don't use 10w-40 conventional oil because the polymers that they use to make it multiweight do not provide lubrication, and do not protect well at higher temps. Synthetic is good though.
If you do use synthetic, keep your eye on the oil level the first couple times you change the oil. Some have reported increased oil consumption with Synth. I have personally noticed it in my truck over long oil changes (7000 miles).
Guest Paul Felker
I agree with Dcarrow a 10w30 o2 20w50 are great choices product preference? AMSOIL all the way! I put it in all my vehicles and customer cars when ever i can talk them into it.
short answer? a good synthetic 10w30 or 15w40 will suit almost all engines well
first you should realise that the OIL system does much of the engines cooling and a 7-8 qt baffled oil pan will normally absorb and cool the engine a great deal more than a 5 quart oil pan, due to both the larger oil supply and the larger surface area on that larger oil pan thats outer surface has a greater area expossed to the cool air flowing under the car that will normally be well over 120 degrees cooler than the oil inside that oil pan.
adding a 8qt oil pan helps cool the engine a great deal, so much in fact that the 10.5qt custom oil pan on my corvette require the use of a 190f thermostat just to allow my oil to get to the minimum 215f degs necessary to burn off the moisture that sometimes accumulates in a non-running engine!
ead this over carefully
IVE POSTED MOST OF THIS BEFORE BUT IT FITS HERE AS A SOURCE OF INFO FOR THE NEWER GUYS
the thinner the oil the faster it flows, the faster it gets to the surfaces that need the oil film, and the easier it is for the oil to flow thru the clearances,the engines operating temp. the engines clearances,and the oils thermal limits plus the engines ability to maitain sufficiant oil pressure and volume over the engine entire operating range effects the best oil choice.
since mineral and SYNTHETIC OILS in the 10w30 or 10w-40 range are the standard for most engines thats what the clearances are set up for in most engines
I found this diagram I find it interesting but all the data I've seen before I saw this diagram and which I trust considerably more than this diagram tends to point to slightly higher average temperatures being ideal.
I have repeatedly said that your oil temp should keep above 215° to allow moisture to burnout of the oil and that your coolant temp should stay in the 180-220 range, remember OIL IS THE MAIN LIQUID CARRIER OF HEAT AWAY FROM THE RINGS,BEARINGS,ROCKERS,SPRINGS,AND PISTONS, AND ITS OIL RUNNING DOWN THE INNER BLOCK SURFACES THAT ALLOWS THAT HEAT ABSORBED BY THE OIL TO TRANSFER TO THE BLOCK AND COOLANT http://www.melling.com/highvol.html
http://www.melling.com/engoil.html
here this might help
read this over carefully
ok lets look at a few things, pressure is the result of a resistance to flow , no matter how much oil is put out by the oil pump there is almost no pressure unless there is a resistance to that oil flow and the main resistance is from oil trying to flow through the bearing surface clearances and once the pumps output pressure exceeds the engines ability to accept the oilflow at the max pressure the oil return system/bypass spring allows the oil circles back through the pump ,now the amount of oil flow necessary to reach the furthest parts in the engine from the oil pump does not go up in direct relation to rpm, but it instead increases with rpm at a steadly increaseing rate that increases faster than the engine rpm due to centrifugal force draining the oil from the rods as they swing faster and faster since energy increases with the square of the velocity the rate of oil use goes up quite a bit faster due to the greatly increased (G-FORCES) pulling oil from the rod bearings over 5000rpm going to 8000rpm than the rate of oil flow increases from 2000 rpm to 5000rpm (the same 3000rpm spread) and remember the often stated (10 lbs per 1000rpm)needs to be measured at the furthest rod and main bearing from the pump not at the pump itself, next lets look at the oil flow itself, you have about 5-6 quarts in an average small block now the valve covers never get and hold more than about 1/3 to 2/3 of a quart each even at 8000 rpm (high speed photography by SMOKEY YUNICK doing stock car engine research with clear plastic valve covers prove that from what Ive read) theres about 1 quart in the lifter gallery at max and theres about 1 quart in the filter and in the oil passages in the block, that leaves at least 2 quarts in the pan at all times and for those that want to tell me about oil wrapped around the crankshaft at high rpms try squirting oil on a spinning surface doing even 2000rpm (yes thats right its thrown off as fast as it hits by centrifugal force, yes its possiable for the crankshaft WITHOUT A WINDAGE SCREEN to keep acting like a propeler and pulling oil around with it in the crank case but thats what the wrap around style milodon type windage screen is designed to stop)the only way to run out of oil is to start with less than 4 quarts or to plug the oil return passages in the lifter gallery with sludge or gasket material! now add a good windage tray and a crank scrapper and almost all the oil is returned to the sump as it enters the area of the spinning crankshaft! forming a more or less endless supply to the oil pump, BTW almost all pro teams now use DRY SUMP SYSTEMS WITH POSITIVE DISPLACEMENT GERATOR PUMPS that are 3,4,or 5 stage pumps each section of which has more voluum than a standard voluum oil pump because its been found total oil control is necessary at high rpms to keep bearings cool and lubed
NOW I POSTED THIS BEFORE BUT IT NEEDs REPEATING
ok look at it this way,what your trying to do here is keep an pressureized oil film on the surface of all the bearings to lube and cool them and have enough oil spraying from the rod and main bearing clearances to lube the cam and cylinder walls/rings. now a standard pump does a good job up to 5000rpm and 400 hp but above 6000rpm and 400hp the bearings are under more stress and need more oilflow to cool and because the pressure on the bearings is greater you need higher pressures to maintain that oilfilm.lets look at the flow verus pressure curve. [color:"red"] since oil is a liquid its non-compressable and flow will increase with rpm up to the point where the bypass circuit starts to re-route the excess flow at the point were the pressure exceeds the bypass spring pressure. but the voluum will be equal to the pumps sweep voluum times the rpm of the pump, since the high voluum pump has a sweep voluum 1.3-1.5 times the standard pump voluum it will push 1.3-1.5 times the voluum of oil up to the bypass cicuit cut in point,that means that since the engine bearings leakage rate increases faster as the rpms increase because the clearances don,t change but the bleed off rate does that the amount of oil and the pressure that it is under will increase faster and reach the bypass circuit pressure faster with the high voluum pump. the advantage here is that the metal parts MUST be floated on that oil film to keep the metal parts from touching/wearing and the more leakage points the oil flows by the less the voluum of oil thats available for each leakage point beyond it and as the oil heats up it becomes easier to push through the clearences.now as the rpms and cylinder preasures increase in your goal to add power the loads trying to squeeze that oil out of those clearances also increase. ALL mods that increase power either increase rpms,cylinder preasures or reduce friction or mechanical losses. there are many oil leakage points(100) in a standard chevy engine.
16 lifter to push rod points
16 pushrod to rocker arm points
32 lifter bores 16 x 2 ends
10 main bearing edges
9 cam bearing edges
16 rod bearing edges
2 distributor shaft leaks
1 distributor shaft to shim above the cam gear(some engines [/color] that have an oil pressure feed distributor shaft bearing.)
so the more oil voluum the better,(AS LONG AS ITS TOTALLY UNDER CONTROL ON BOTH THE PRESSURE AND RETURN/SCAVAGEING SIDES OF THE SYSTEMchevy did an excelent job in the design but as the stresses increase the cooling voluum of the extra oil available from the larger pump helps to prevent lubracation delivery failure, do you need a better pump below 5000rpm or 400hp (no) above that level the extra oil will definitely help possiable deficient oil flow and bearing cooling and a simple increase in pressure does not provide a big increase in voluum that may be necessary to keep that oil film in the correct places at the correct voluum at all times.the stock system was designed for a 265cid engine in a passenger car turning a max of about 6000 rpm but only haveing the stress of under 300hp transmitted to the bearings, Im sure the orriginal designers never thought that the sbc or bbc would someday be asked to on occasion hold up to 450-800hp and 6000-8000 rpm.nore did they forsee valvesprings that placed 500lbs and up loads on the lifters and the use of over 9 to 1 compression ratios in the original design so the oil voluums and pressures necessary to cool those valve springs and bearings at those stress levels were never taken into account for that either.
Continued (oil Pan/pump)
the oil pump can only pump as much oil as the engine clearances allow at the max pressure that the oil pump bye -pass circuit will allow, and no more. for your idea to be correct (which it could be under some conditions)the oil flow through the engine clearances would need to be so great that the pump turning at 3500rpm,7000rpm engine speed(remember the pump spins 1/2 the speed the crank does)and most likely pumping at max pressure could lower the oil level to the point that the pick-up becomes uncovered or a vortex as you call it forms and the pump starts sucking air.
now under hard acceleration it is very possiable for the pickup on ANY oil pump to to become uncovered in a oil pan that has less than 5qt capacity and with no oil control baffles as the oil rushes to the rear of the oil pan if the pick-up is located in mid pan or under hard brakeing if the pick-up is located at the rear of the pan on a non- oil baffle controlled pan.
I will grant you that it is possiable for ANY oil pump to pump a good amount of oil into the lifter gallery at high rpms IF THE OIL RETURN PASSAGES IN THE HEADS AND LIFTER GALLERY ARE BLOCKED, preventing its normal return to the crankcase
, but running a high volume oil pump will have little or nothing to do with how much oil is in the pan if the engines drain back holes are clear and your useing a milodon style windage screen. I have several times had that same complaint about lack of oil pressure under acceleration but it is caused by a non-baffled pan or the pickup mounted so close to the pan bottom that the pump cant get a good intake flow, if you carefully check youll find that on a dyno runs it seldom happens,because the oil is constantly removed by the windage screen is returned to the sump, most of the oil pumped into the system exits at the rod and main bearing clearances or at the cam bearings and from the lifter bores lower ends, its not the constant oil flow or lack of oil into the rocker arms that has the big effect on total oil flow as SMOKEY YUNICKS PHOTOGRAPIC RESEARCH PROVED YEARS AGO,its the oil flowing from the bearings and lifters and that oil flow is quickly returned to the sump by a windage screen scrapeing it off the spinning crank and rods as the spinning assembly passes over the windage screen. in effect most of the oil in an engine works like your timeing chain in that it constantly cycles top to botton and back never getting higher than the cam bearing lifter area.
now what does quite frequently happen is that the guys installing a high volume oil pump just swap out the standard pump, reinstall the stock or simular pick-up and bolt on the pan with the pick-up in the stock possition on the oil pump. the stock pick-up is mounted about 3/8" off the pan bottom,the high volume pump is normally equiped with impeller gears about .3 inches longer than stock, the high volume pump body is that much lower in the pan, resultting in the pick-up being only about 1/8" from the pan bottom. the result is that on a normal chevy oil pump pick-up this leave a space of about 1/8" x 2.5" for oil to flow into the pump. at low rpms this works but as the rpms climb the pick-up that can,t get any oil to pump cavitates as it spins and fails to pump oil, result oil pressure drops untill rpms are lowered no matter how much oil is over the pick-up. simply checking to make sure that anout 1/2" of space is under the pick-up when the pan is installed cures that problem (a simple trick is to weld a 1/2" thick nut to the oil pump Pick-up base and test fitting the pan BEFORE WELDING THE PICK-UP TO THE PUMP BODY)
what it comes down too in every case that Ive looked into so far is a improperly positioned pick-up or a non- baffled oil pan without a windage screen or less than 5 qts of oil in the system, not a problem of all available oil being pumped into the lifter gallery and valve covers like some people would like you to think.
the MELLING COMPANY HAS THIS TO SAY
Most of the stock automobile engines are designed to operate from idle to 4500 RPM. The original volume and pressure oil pump will work fine in this type of application. As the demands on the engine increase so does the demands on the oiling system and pump.
The oil pump's most difficult task is to supply oil to the connecting rod bearing that is the farthest from the pump. To reach this bearing, the oil travels from three to four feet, turns numerous square corners thru small holes in the crankshaft to the rod bearing. The rod bearing doesn't help matters. It is traveling in a circle which means centrifugal force is pulling the oil out of the bearing.
A 350 Chevy has a 3.4811 stroke and a 2.111 rod journal. The outer edge of the journal travels 17.5311 every revolution. At 1000 RPM, the outer edge is traveling at 16.6 MPH and 74.7 MPH at 4500 RPM. If we take this engine to 6500 the outer edge is up to 107.9 and at 8500 it is 141.1 MPH. Now imagine driving a car around a curve at those speeds and you can feel the centrifugal force. Now imagine doing it around a circle with a 5.581, diameter.
The size of the gears or rotors determines the amount of oil a pump can move at any given RPM. Resistance to this movement creates the pressure. If a pump is not large enough to meet the demands of the engine, there will not be any pressure. Or if the demands of the engine are increased beyond the pumps capabilities there will be a loss of oil pressure. This is where high volume pumps come in; they take care of any increased demands of the engine.
Increases in the engine's oil requirements come from higher RPM, being able to rev faster, increased bearing clearances, remote oil cooler and/or filter and any combination of these. Most high volume pumps also have a increase in pressure to help get the oil out to the bearings faster.
That is what a high volume pump will do. Now let Is consider what it will not do.
It will not replace a rebuild in a worn-out engine. It may increase pressure but the engine is still worn-out.
It will not pump the oil pan dry. Both solid and hydraulic lifters have metering valves to limit flow of the oil to the top of the engine. If a pan is pumped dry, it is because the holes that drain oil back to the pan are plugged. If the high volume pump is also higher pressure, there will be a slight increase in flow to the top.
let me point out this chart
http://www.diabolicalperformance.com/clearances.html
heres other info,
http://www.babcox.com/editorial/ar/ar10180.htm
http://www.thirskauto.net/BearingPics.html
http://www.waynesgarage.com/docs/oil.htm
http://www.jimcookperformance.com/TechNotes/TN%2023.html
http://www.cryoeng.com/images/EngineDurabilitySecrets.htm
http://members.aol.com/carleyware/library/engine2t.htm
HERES more info on oil and filters HERE READ THESE
http://www.babcox.com/editorial/us/uhs69720.htm
http://www.co.broward.fl.us/aqi03202.htm
http://www.motoroilbible.com/five.html
http://www.motoroilbible.com/two.html
http://www.motoroilbible.com/six.html
http://www.exxon.com/exxon_lubes/tigerbytes/documents/brochures/bro0020.htm
http://www.atis.net/oil_faq.html
https://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf/26 b7c4b33367a4a086256665004e4266/61638dff7d0453b085256b8400618b40?OpenDocument
http://www.triumphspitfire.com/Oiltest.html
http://www.fernblatt.com/longhurst/engineoil_bible.html
http://minimopar.net/oilfilterstudy.html
http://www.seansa4page.com/resource/synth.html
http://www.geocities.com/MotorCity/Downs/3837/oilprime.html
AND FOR THOSE OF YOU THAT DON,T WANT TO READ THROUGH THE LINKS THE SHORT ANSWER IS
(1)MOST OILS AVAILABLE TODAY ARE VERY GOOD QUALITY AND FAR EXCEED WHAT WAS AVAILABLE EVEN TEN YEARS AGO.
(2)CHANGING YOUR OIL AND FILTER OFTEN AND NEVER RUNNING LOW ON OIL IS THE KEY TO LONG ENGINE LIFE
(3)SYNTHETIC OILS DO HAVE A SIGNIFICANT ADVANTAGE AS FAR AS HEAT RESISTANCE AND HIGH HEAT LUBRACATION
(4) IF YOU DON,T ABUSE OR OVERHEAT YOUR ENGINE THERES LITTLE DISADVANTAGE TO USEING GOOD DINO BASE OIL UNDER 240 DEGREES OF ENGINE TEMP AS LONG AS YOU CHANGE OIL OFTEN
(5)SYNTHETIC OIL DOES HAVE A BIG ADVANTAGE WHEN ENGINE OIL TEMPS EXCEED 260 DEGREES (F)
oil info
heres what consumer reports says about the better oils available
http://www.unofficialbmw.com/all/misc/all_oilfaq.html
All of the oils above meet current SG/CD ratings and all vehicle
manufacture's warranty requirements in the proper viscosity. All are "good
enough", but those with the better numbers are icing on the cake.
The synthetics offer the only truly significant differences, due to their
superior high temperature oxidation resistance, high film strength, very
low tendency to form deposits, stable viscosity base, and low temperature
flow characteristics. Synthetics are superior lubricants compared to
traditional petroleum oils. You will have to decide if their high cost is
justified in your application.
I use puralator pure 1 filters or mobile 1 filters and mobile 1 synthetic oil 90%-95% and 10%-5% marvel mystery oil. ALL APPLICATIONS, read this,
https://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf/26b7c4b33367a4a086256665004e4266/61638dff7d0453b085256b8400618b40?OpenDocument
http://www.shotimes.com/SHO3oilfilter.html
What aboutthose 'miracle lubes' like Slick 50? I saw a new one the other day called "Prolong" where they dump dirt onto the crank of an upside-down engine? I dunno about you, but I rarely run my engine upside-down with the oil pan off.. :roll:
"Miracle oils" in an engine with 100k+ miles?
