Does this sound like a good turbo for me
Guest ZmeFly
Of course as Im upgrading with the Z31 ECU and the like New and larger injectors Im also eventually looking to upgrade the turbo.
I found this one and here are the specs.
Does this sound good for the L28ET?
A/R ..70/.82
Compressor wheel dia.: inducer 2.30" exducer 2.75"
Turbine wheel dia.: 2.5"
Compressor inlet: 2.5"
Turbine outlet: 2.4"
Standard T3 flange
Standard T4 backplate
I wouldn't have such low expectations with the HP unless you are talking rear wheel. TO4E's don't flow any more than T4B's. To do again I would start with a 60-1 and either full T4 or stage 3 or 5 on a T3 turbine. If you buy one of those cheap ebay turbos make sure it isn't an S trim T4B.
Thanks for the info. Now I know a little more about what to look for.
I always get confused with the maps and what not, but Blue put it into a little better perspective with the boost levels and where they hit.
Once again thanks
