olie05 Posted February 28, 2004 Share Posted February 28, 2004 I just talked to the guy at the machine shop, and he said that I have to clearance my thrust bearing to fit (for front to back movement). He said that I could either do it at home or he could do it for me. Do you think that a file and micrometer gauge will be adequate or should I take it back to the machinist and get it milled perfectly? Quote Link to comment Share on other sites More sharing options...
Clifton Posted March 1, 2004 Share Posted March 1, 2004 I used a sheet of I think 400 grit sandpaper on a smooth surface and held both shells and went at till they fit. I checked them with the calipers as I was sanding to make sure I was getting them even. I rotated them 90* every so often also. Came out fine. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 2, 2004 Share Posted March 2, 2004 same here: oil, glass plate, and some 400# wet-n-dry paper... Quote Link to comment Share on other sites More sharing options...
