Guest zline Posted July 6, 2004 Share Posted July 6, 2004 Joel - The Z32 box looks very similar to the RB25 box as they are the same model and internals. F5R30A I believe. Here is the mission breakdown for most nissans 71C 280Z 240SX S13 silvia with CA18DET S13/14 silvia with SR20DET All year Z31 NON TURBO Nissan trucks with KA/Z22/Z24 motors (you CANNOT use this mission in cars, its to short and the shifter is HUGE and it is closer in the trans tunnel than the mission itself. we have a few at the shop that are laying on the floor..customers made oopsies) 30A Z32 Z31 kouki turbo any 71C mission will bolt the the bellhousing for the proper car ie., DOHC KA/SR with DOHC KA bellhousing or SR bellhousing for SR motor. You can swap single cam mission onto dual cam block and vice versa if you just use the proper bellhousing easiest way to do the 350z mission would be an adapter Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted July 6, 2004 Share Posted July 6, 2004 The 280Z uses a 71B tranny - single cone syncros, L series bellhousing, different shifter, etc. Doug Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 6, 2004 Share Posted July 6, 2004 i know theres one with a 71C box i think it was an optional or whatever. i might be wrong Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted July 7, 2004 Author Share Posted July 7, 2004 Here is another 350z 6 spd for sale >>>> http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33733&item=7909048396&rd=1 Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 7, 2004 Share Posted July 7, 2004 wonder if i could jank that into my S14....humm... Quote Link to comment Share on other sites More sharing options...
ToplessZ Posted July 8, 2004 Share Posted July 8, 2004 Hold on a sec. from what Im reading it will bolt onto a ka bell housing or SR so it should bolt in with little modifications on a sr20 powered vehicle. One more reason to have the sr20det swap I wonder what it would take to adapt it to our old l6's Quote Link to comment Share on other sites More sharing options...
Thaniel Posted July 8, 2004 Share Posted July 8, 2004 Well I tried to hook up the speedometer to the 350z trans. Bad news. There is no speed sensor on the trans. The speed signal is derrived from the ABS sensors. Always something. Check it out for yourself below is a link from a 350z forum with documentation. http://www.350zforum.com/net/viewmsg.aspx?forum=technical&msg_id=4597 Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 8, 2004 Share Posted July 8, 2004 got pics of your FC with the VQ?? how do you like it? Quote Link to comment Share on other sites More sharing options...
Thaniel Posted July 8, 2004 Share Posted July 8, 2004 got pics of your FC with the VQ?? how do you like it? See http://www.torquecentral.com/showth...9953#post199953 So far it seems like it is going to be a great car. Too soon to tell for sure as I haven't had enough time with it on the road. Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 8, 2004 Share Posted July 8, 2004 how'd you get the speed sensor working? Quote Link to comment Share on other sites More sharing options...
Thaniel Posted July 9, 2004 Share Posted July 9, 2004 how'd you get the speed sensor working? Right now there isn't a speed sensor. Currently the wire from my speedometer is dangling in the air I'll have to rig up a sensor off the drive shaft or one of the hubs or something. That will have to wait until later though. Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 9, 2004 Share Posted July 9, 2004 ohh okay.. what about converting it to mechanical drive like they do with the 4L60/80E transmissions? Quote Link to comment Share on other sites More sharing options...
Thaniel Posted July 9, 2004 Share Posted July 9, 2004 ohh okay..what about converting it to mechanical drive like they do with the 4L60/80E transmissions? Can't do it. The trans doesn't have a mechanical drive. The only things on the trans are the neutral switch and the reverse switch. In the 350z speed sensing did not come from trans. Wish it did. I've never seen a trans like that before. Probably the wave of the future. Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 9, 2004 Share Posted July 9, 2004 4L60/80E chevy trans has a computer drive thing just like the Z33 but they convert it to mechanical drive somehow... Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted July 9, 2004 Share Posted July 9, 2004 Did the Rx-7 come with ABS in '91? If it did, you could use the same style of system to run your speedo - You may have to go aftermarket on the speedo. What are you using for VSS for your engine control computer? Doug Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 9, 2004 Share Posted July 9, 2004 sorry to keep slamming you with questions thaniel but this one is kinda important =) is the VQ30 sump from the maxima front mid rear ??? thanks dude! Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted July 10, 2004 Share Posted July 10, 2004 Zline - The engine in my 01 Max has a front sump. Quote Link to comment Share on other sites More sharing options...
Guest zline Posted July 10, 2004 Share Posted July 10, 2004 did i mention i loved you guys? LOVE Quote Link to comment Share on other sites More sharing options...
Thaniel Posted July 13, 2004 Share Posted July 13, 2004 Did the Rx-7 come with ABS in '91? If it did' date=' you could use the same style of system to run your speedo - You may have to go aftermarket on the speedo. What are you using for VSS for your engine control computer? Doug[/quote'] The ECU gets the VSS signal from the instrument cluster (at least on the maxima). The cruise also gets the signal from the instrument cluster. The Maxima cluster I have gets it's signal from a speed sensor in the trans. It's the 350z that is being different ABS was optional on my car. I could buy an ABS hub and sensor but I am not sure the signal will be suitable. (the 350z ran the signal through the ABS computer first) I plan to run the signal through a converter so it can be calibrated. I may just put a sensor on the driveshaft or rear axle. Just not sure what sensor to use. Probably easier than retro fitting the abs sensor. Guess I still haven't decided yet though. Quote Link to comment Share on other sites More sharing options...
Thaniel Posted July 13, 2004 Share Posted July 13, 2004 I've been driving my car a bit and I may have the dreaded 350z 3rd gear grind!!! Anyone hear if there is a fix for it? Can I rebuild the syncro or is some dimension on a critical part way off? It doesn't grind always. Only when I am pushing it real hard. Maybe some synthetic in the trans would be enough.... Quote Link to comment Share on other sites More sharing options...
