Help with electronic speedo
RB26powered74zcar
Do you want to keep the stock guage? If not you can probably use one of the electronic speedometers on the market.
Most of us LT1 guys are using a 5" Autometer speedo. It will work under the following parameters:
• Pulse rate generated proportional to vehicle speed.
• Output within the voltage ranges listed below:
4.0 to 16 V peak (Square Wave), 3 wire
2.0 to 120 V peak to peak (Sine Wave), 2 wire
It would be nice if you had access to an oscilloscope to verify the output is within these parameters, however I'd bet it will work.
