MSA springs question
Guest datsun280zmike
i am putting on MSA springs and kyb shocks nothing crazy...does anyone have MSA springs? if so do you guys have any camber problems? and how many inches do the springs actually lower the car..thanks
mike
just the regular MSA springs...not the euro ones...i think they say it lowers the car 1 1/2 but i could be wrong...i just dont want camber and alignment problems...lol youll probably have your car done before mine..my car basically looks like a shell with a cage in it..
I have the MSA lowering springs on my ZX. They raised the car about three inches from my stock springs. Made it look like a 4x4. With the springs out, free length is about two inches shorter than my stock springs. But the compression rate is quite higher, so they don't compress as much. I cut one coil off each spring to get it to the same height as with stock springs. When I get my wheels mounted, I will cut more to get desired height.
  Quote
Was that WITH or WITH OUT the engine in the car? I noticed that mine sat pretty much in the same place as the stockers with the drivetrain out, will see how she sits with it in.
