need site to L24-L28 block&head swaps=compressions
240zprace
It may just be too big. It was zipped though. I was trying to send you the L series engine calculator. You can plug in head head gasket thickness, rods, crank, block, even change the cc's on the combustion chambers and it will calculate the compression ratio for you.
I'll try sending it again. I'm guessing you won't get it if you didn't the first time. Maybe someone else has a link to a site that has it so you can download it....
Just checked, it is 348K. That's not very big. Sent again...
Jon
Hopefully someone else knows of a site where you can download it yourself. Should be an attached file. When I sent it it took an appropriate amount of time to send the mail with the file attached, so it did go out with the email. Sorry, but I guess you'll have to find it online somewhere.
Jon
