Mike C Posted October 28, 2002 Share Posted October 28, 2002 Got a used LT1 hydraulic roller from a buddy. Supposed to be a Crane. I had no luck on their website, so maybe somebody else can decipher? (Checked Comp out as well, no luck.) Engraved on the end of the cam, 3108 3110 HR113 CC F7399 Quote Link to comment Share on other sites More sharing options...
MYRON Posted October 28, 2002 Share Posted October 28, 2002 have you tried Crower? Myron Quote Link to comment Share on other sites More sharing options...
Mike C Posted October 28, 2002 Author Share Posted October 28, 2002 I have now They say on th eweb that all of their cams have their full name on them. I searched for part#'s also, and no luck. Thanks for the tip, though. Quote Link to comment Share on other sites More sharing options...
Mudge Posted October 28, 2002 Share Posted October 28, 2002 He has no idea what it is approximately in duration? The two I remember are a 222/230 and a 234/242 I believe... Quote Link to comment Share on other sites More sharing options...
Mudge Posted October 29, 2002 Share Posted October 29, 2002 BTW, Competition Cams uses HR, and HR113 is a cam of thiers, so I'd bet there is a good chance its not a Crane. Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted October 29, 2002 Share Posted October 29, 2002 It may only be coincidence, but check out the hydraulic roller lobe specifications chart in Comp Cams online catalog, Pg. 229. http://compcams.com/catalog/229.html. Physical verification should be possible... Quote Link to comment Share on other sites More sharing options...
Mike C Posted October 29, 2002 Author Share Posted October 29, 2002 Thanks. I doubt it is just coincidence. The 3108 and 3110 numbers showed nothing when I searched, and looking under the LT1 cams, they don't have one with those lobe specs. I wonder if it is a custom LT1 grind as they don't offer it in their catalog. Come to think of it, I better check and make sure it has the hole for the waterpump drive, although it DOES have the LONG dowel. 270/284 advertised 215/224 @ .050 .500/.500 lift with 1.5 rockers and I'm guessing HR means hydraulic roller and 113 lobe seperation? I am going to pocket port the iron head LT1 I have, slap this cam in it, and drop it in the Z. Quote Link to comment Share on other sites More sharing options...
Mudge Posted October 29, 2002 Share Posted October 29, 2002 Long dowel would be for the 95+ LT1, porting iron heads? Ouch, have fun! Quote Link to comment Share on other sites More sharing options...
Mudge Posted October 30, 2002 Share Posted October 30, 2002 http://www.compcams.com/catalog/229.html Quote Link to comment Share on other sites More sharing options...
