Guest Anonymous Posted November 15, 2002 Share Posted November 15, 2002 I'm down to wiring on my LT1 conversion. For about 3 weeks now I have been working furiously to swap an Impala SS LT1 (YES, the 5.7L) into my 1995 240SX. Everything is ready now, and we're just running the new Painless harness. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted November 15, 2002 Share Posted November 15, 2002 Are you going to edit the PCM? If so what application are you going to use? I am using TunerCat and really like it, but since I haven't used any others, I'm curious. I am also using freeScan to check and reset diagnostic codes....it's really cool and free. Tim Quote Link to comment Share on other sites More sharing options...
Sumo Posted November 15, 2002 Share Posted November 15, 2002 Dont you have emissions testing down in Houston too similar to DFW? Quote Link to comment Share on other sites More sharing options...
Wagz Posted November 16, 2002 Share Posted November 16, 2002 I'd love to see some pics of the coversion! Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted November 16, 2002 Share Posted November 16, 2002 Yes, Pictures of the conversion would be cool! Mike Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 19, 2002 Share Posted November 19, 2002 I thought OBDII allows program updates via software? In fact, I think it is a requirement. So all 95 and newer LT1's should be reprogramable via laptop. Why are you "burning a chip" with OBDII? Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted November 19, 2002 Share Posted November 19, 2002 It is my understanding that when GM wen tto the PCM that it was software programmable - not reliant on hardware anymore. OBDII may have some limitaiton built in that the first two years of the PCM did not.... How close am I on this guys? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 20, 2002 Share Posted November 20, 2002 Originally posted by Tim240Z:Are you going to edit the PCM? If so what application are you going to use? I am using TunerCat and really like it, but since I haven't used any others, I'm curious. I am also using freeScan to check and reset diagnostic codes....it's really cool and free. Tim We're going to have MTI here in Houston burn us a custom chip with a modified fuel map for the car.After that, everything will be tuned with a Hypertech Power Programmer (ODB2). Emissions here are a royal pain. I'm in Harris County in Houston, and our emissions are almopst as strict as Califonia's. They even put the car on a primitive dyno to test the emissions. I will take some more pictures tonight, and see if I can upload them all tomarrow for everyone to see. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted November 20, 2002 Share Posted November 20, 2002 OK so you have a newer OBDII LT1 huh? My statement/questions are moot then Tim Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 20, 2002 Share Posted November 20, 2002 Originally posted by Tim240Z:OK so you have a newer OBDII LT1 huh? My statement/questions are moot then Tim No, your questions are good.You can always modify the setup to handle ODB1 input. I just find it easier to work with ODB2 Quote Link to comment Share on other sites More sharing options...
Tim240z Posted November 20, 2002 Share Posted November 20, 2002 I just find it easier to work with ODB2 [smile] Huh, hows that?OBDI allows full interface tuning and PCM changes from a laptop. No chip burning etc. Forgive my ignorance, but please explain. Tim Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 20, 2002 Share Posted November 20, 2002 Originally posted by Tim240Z: quote: I just find it easier to work with ODB2 [smile] Huh, hows that? OBDI allows full interface tuning and PCM changes from a laptop. No chip burning etc. Forgive my ignorance, but please explain. Tim There are plugs made to allow the laptop interface of ODBI setups to the ODBII connections. Yes your options on tuning are greatly limited (timing, air/fuel, transmission line pressure, sensor activation temperatures and variables) but it can still be done Quote Link to comment Share on other sites More sharing options...
