93-96 Camaro starter w/11:1??
Anyone try this starter with a high comp motor? Trying to figure if it has enough juevos to turn 11:1 over on a regular basis. Pulled 125 amps on the machine, but know way of knowing how it will work until start up day. The sob was expensive. Looking at the gear reduction mini as a alternate. Perf shop employee has it on his 13:1 bigblock...$157.00.
John
The late model LT1 starter IS a gear reduction starter. It's pretty neat. Uses a bunch of little planet gears keyed to the armature shaft then rotating inside a sun gear. (I've got one on the bench MOSTLY disassembled, can't find a female torx driver that is small enough. Lisle set available at sears-craftsman doesn't make one-was able to get the brushes out but not the solenoid off. Highly irritating. Has a short in it from corrosion, came out of a boat but was free!)The LT4 is something like 10.5:1 and uses that starter, the LS1 is 11:1 and my guess uses the same motor but different mounting. Should work great. GM performance parts gets $189 for the 168 tooth flywheel starter, but they have the 153 rebuilt for $89!
Tried one on my 383 - sourced it from an Impalla SS application. It never shimmed right and when it would catch to crank it labored. Bought a gear reduction starter from Jegs and it cranks like mad now! Bought one of their cheapies too! Didn't even have to shim the JEg's starter. Keep meaning to E-Bay my LT1 starter but haven't had the chance. Almost no miles on this sucker so if someone else wants to give it a whirl lemme' know.
BLKMGK,
Do you feel your starter was unable to perform because it was a weak design? Was your starter a brand new one-or used from a salvage yard? If it was used then it may have been defective to begin with(?). Was your flywheel new?
If both your flywheel and starter were used; then possibly the Starter Bendix & flywheel teeth together were worn enough, so much so, that they were out of tolerance. With the advent of the new starter from JEG's your starter bendix brought the two teeth into mesh, within tolerance enough, to solve your problems.
Just curious as to why a GM starter was inadequate. Glad you found a starter from JEGs.
Did the JEG's starter fit w/out any hassle?
Kevin,
(Yea,Still an Inliner)
Cool! I was wondering about the gear reduction with the sub 3" diameter. Most g.r have an offset pinion. I used this on my 4.3, 7.5:1 was pretty easy to spin! Wasn't sure how it would handle the compression & exta 2 cylinders. It was reconditioned when I bought it, maybe I'll try the engine stand test. Come on push rods (arrive tomorrow) and headers ship today!!
John
Mine was "new" from a local parts house. It just didn't seem to have enough "oomph" when it didn't make awful grinding sounds. Flywheel was a brand new Centerforce, thankfully it doesn't seem to be damaged. The Jeg's starter bolted right up and is nice and SMALL. Don't recall the brand but could probably find it if you would like.
If it is the Nippondenso motor (like the one in the 89 Corvette in the JTR manual) it is made by CVR. I have one on each of my trucks. Work great for the $150. I'm hoping to have better luck with the Delco starters as my boat mechanic buddy will give them to me. :D
I've been surfin' the net a little, and it looks like there may have been a couple of different starters. The GM starters I have have a tail piece (about 2" thick) a middle piece (also about 2" thick) and then the nose. The bolts that hold it together run INSIDE the case. This is the gear reduction starter. The other one looks like a regular GM starter with just a steel cap over the back and the bolts that hold it together are OUTSIDE the case. Which one did you have Blkmgk?
OK, got some more starters today. Looks like there aare at least 3 different ones. The multiple stage ones with bolts inside and the mult stage with bolts outside, then the slightly shorter one with just the stamped cover over the end. Be interesting to here which ones people have used and what the successes were.
I make my own cables. Home depot has 2ga welding cable for 90 cents a foot(unbelieveabley fine conductors and really good insulation) and I have a GIANT set of crimpers (designed for wire rope ferrules). Get some lug terminals from the welding section and I use the expensive but nice waterproof battery cable heat shrink from Jegs. In my experience, the fender mounted solenoid is not needed with a gear reduction solenoid.
I got out the JTR book to look at your starter. According to them, number 7 is a heavy duty GEAR REDUCTION starter. Most of the ones I have are like number 3 in the photo. The number 3 is available with both noses (straight and angled bolts) for both flywheels. My '96 LT1 came with a starter like that. I don't know if it was the original or not, but with only 30k miles on it I assumed it was, but who knows? I bought the starter that looks like #8 for both of my trucks. Cast iron bellhousings have a bellhousing mount starter like the Datsun and the regular nose won't go in the hole. The books says it won't work on the V8 Datsun, but doesn't somebody here have that one? Also, the JTR manual (the bible, right?) says that #3 and #7 are the best of all the starters. I am assuming that yours is just worn out? Brushes and a new solenoid should fix it right up. I took two apart and combined the pieces last week to get it working. I am going to put it on my camaro eventually and will post results.
Originally posted by Mike C:
I got out the JTR book to look at your starter. According to them, number 7 is a heavy duty GEAR REDUCTION starter...Also, the JTR manual (the bible, right?) says that #3 and #7 are the best of all the starters. I am assuming that yours is just worn out? Brushes and a new solenoid should fix it right up. I took two apart and combined the pieces last week to get it working. I am going to put it on my camaro eventually and will post results.
My starter has only a few hundred miles, bought it when I switched to my 6 speed. The JTR book probably assumes a stock 350 will be going in to most conversions. My #7 starter doesn't turn 11:1 383 compression very well. Slow and steady, but not like I'd expect. The mini, like I said was much, much stronger. Maybe there was a problem with mine from the start, as it was new/reconditioned, not new from Chevy. Just never showed up with the low compresion 4.3. Hope you have better success.
John
Not satisfied with my 93-96 starter. Marginal cranking. Sucked up and got the Mini. Using the same wiring, no comparison, the mini does a better job, period. The gear reduction used less power, but I still like the fender solinoid. No question if the power is going to both starter and solinoid, and eliminates one wire where I can't get to it easily.
John
  • 2 months later...
Finally, here are some pics of the GM gear reduction starters I have. I have had a couple apart, and the one from a 4 cylinder is for 168 tooth flywheel but has a different gear ratio, the plastic sun gear was even ruined on this one. The smallest cased starter 2nd from the right is the 4 banger one. The starter on far left is 168 tooth and the far right is same starter with 153 tooth nose. The second starter from left is a different style one for the 168 tooth flywheel. In the exploded view, the plastic piece attached to the bendix is the sun gear. The planets revolve around it and the armature shaft. The self-contained brush assembly has a Craftsman socket in it to hold the brushes in their holders with springs compressed. Learned how to do THAT the hard way also. :rolleyes:
