Adjustable S30 Rear Control Arm Bushing Sources
These are for my wife's 280Z which has a bad toe in problem. I've got new tires on there and they are already showing wear. I'm not sure if you can just buy one set, but wouldn't it deform the other inner busings? I have poly ones on there now.
Thanks,
Pete
It's a trick I learned from another racer. It's only a slight angle change so it doesn't seem to hurt anything. Probably adds a little bump steer but it makes toe setting a breeze. I mis-quoted earlier, run a poly bushing on the front and the adjustable bushing on the rear. You can set the toe without jacking.
I have no idea how I ended up with one pair. If they do come in sets of 4 maybe you can split with someone.
