15x8 on back, 15x7 on front ?
15" will be worse because a shorter wheel will ride closer to the spring and perch because they angle away from the tire as they go up. I didn't explain it well, but I think you know what I am getting at. Also, Those wheels probably have a FWD offset, so they will have a large backspace. Again, you have to compare the wheels you are looking at to stock and others that have done this. You should be able to find tons of threads on wheel fitment. It is all here, just keep digging.
How much for the Simmons, if you don't mind me asking :) Very hard to get in those sizes eh.
Surest way is to measure the amount of backspace your car will take. Fix a straightedge to the cars wheel hub face and measure back to the struts, springs, etc from there. Have the suspension at ride height.
