Guest 305240 Posted August 20, 2004 Share Posted August 20, 2004 This is what I started with after I set my engine and tranny up. Sorry, this won't let me post multable pics. Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted August 20, 2004 Share Posted August 20, 2004 After sandblasting, using a rust killer acid primer, I painted it with Hammerite paint. It looks pretty clean now. Quote Link to comment Share on other sites More sharing options...
v8dats Posted August 20, 2004 Share Posted August 20, 2004 wow ! nice job. keep us posted Quote Link to comment Share on other sites More sharing options...
Guest Phailure Posted August 20, 2004 Share Posted August 20, 2004 lookin good Quote Link to comment Share on other sites More sharing options...
slownrusty Posted August 20, 2004 Share Posted August 20, 2004 Delicious...nice work!!! Yasin Quote Link to comment Share on other sites More sharing options...
SSflyer Posted August 20, 2004 Share Posted August 20, 2004 OK, this may be a silly question, but where do you hang your hood hinges? Do you have a one piece front end? Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted August 20, 2004 Share Posted August 20, 2004 Check the post by 78alt1 titled "lil help needed, front body measurements" in the suspension section. One front frame horn and header panel was cut off before I got the car. Rather than cut out all the spot welds, I opted to cut the other frame horn off and replaced it with the whole nose piece 0ff a 75 280. I've already done the trial fit and the fenders are bolted, as well as the hood to the replacement header panel. When I get my engine detailed and set back in, I'll put the front clip back on and weld it where it needs to go. I'm getting pretty excited, but the wife has sort of taken up complaining about how much I've been spending on ebay for parts. Gotta love her tho, she won't give up her 86 300ZX coupe for anything. Can't really blame her. It's almost mint. I'm keeping a running total of the cost of this total rebuild, along with step by step pics. Total so far, which includes the car, engine, and other goodies I've purchased is still under 650.00. Ebay rocks! Quote Link to comment Share on other sites More sharing options...
olie05 Posted August 20, 2004 Share Posted August 20, 2004 looks good Is it me or are the frame rails leaning toward the drivers side? ( may be camera angle) Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted August 20, 2004 Share Posted August 20, 2004 It's got to be the camera angle because I set it up with a level. I made sure it was level when I set the engine in. I used a plum bob, yardstick, and lazer level as well as a 2' level. The body was leveled side to side as well as front to back. The carb sets level both ways when the engine is setting in it. It took me almost a half day to get it set up. I sure didn't want it to look crooked and jury rigged! I'm working on a gravel parking area. I leveled that also. You can bet the concrete I pour later on will be level too! those rocks hurt when these old bones lay on them. Quote Link to comment Share on other sites More sharing options...
78zlt1 Posted August 21, 2004 Share Posted August 21, 2004 What media did you use for blasting? and what primer too, Just asking cause I'll be doing the same thing soon too. Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted August 21, 2004 Share Posted August 21, 2004 The media I got from the local gravel pit. It was their plaster mix. About the finest they had. It was free for 2, 5 gallon buckets. Be prepared to get dirty as it all seens to come right back at ya! The primer is the rust killer that NAPA sells. The bottle isn't too big, but I think there is enough to do your whole front end. It's a milky white acid/primer that stops rust. They told me it's the only one they sell. The Hammerite paint is the Ace hardware brand. Don't confuse it with the rustoleum brand. The black actually looks like a dark metalic charcoal. Pretty neat if you ask me. It also has something to do with stoping rust. The underside, I hit it with rubberized undercoating after I got rid of all the slight surface rust spots. It should be noted: When I speak of rust, it's not the deep rust, just slght surface rust that can probably be taken off with sandpaper. I do have some minor rust thru spots, but not large ones. Those issues have already been taken care of. Nothing on any part of anything structual, thank God! Except the upper rear valance. That had about a dozen small rust thru spots on it because the hatch was left open a crack. I cut the whole piece out of the 75 to replace it with. Much easier and will look better. Quote Link to comment Share on other sites More sharing options...
Drftn280zxt Posted August 21, 2004 Share Posted August 21, 2004 very nice job. Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted August 22, 2004 Share Posted August 22, 2004 Thanks guys. Everyone can use a pat on the back every now and again. It helps keep the interest going. Not to mention the pride in doing the work yourself and showing it off. More to come soon! Quote Link to comment Share on other sites More sharing options...
