What is a Hydralic Roller Tappet?
I was going to order the HOTCAM kit for my 93 LT1 and the description says "Does not include roller tappets. See valve lifter section for the lifter kit." So what does that mean? I am going to get new hydralic roller lifters too. Is that what Roller Tappets are?
Thanks,
Guy
Flat tappet/lifter guys swap (are supposed to) lifters when using a new cam, just like L6 guys and rockers. So old timers might wonder if they get lifters with the cam they are buying (which isn't needed nor is a break in procudure needed).
R lifters are better than stock, I sure dont know pump up information on the stock lifters versus R lifters, but I got R anyway for RPM and extended duty.
Hey Mike C or anybody else for that matter would you happen to know the GM part number for those? I found some Hyraulic roller lifters by GM but they are 30.52 a piece which comes out to $488.32 for 16 of them. I am not spending $488 on lifters! Please help!!! malebitchslap.gif
Thanks,
Guy
Oh yeah and heres another question...what kind of rods do I have in my 93 LT1 motor right now(stock)? If they are the PM rods I was going to recondtion them and use ARP bolts. If not I guess I will just have to spend the extra $250 on rods.
Thanks,
Guy
The lifters should be fine with only 103k on them.
12551705 is the part # for the ZZ4 lifters which I THINK are the same as LT1 lifters, but you should check. Jim Pace has them for $234.80, but I haven't priced them in a while, so that may be the new rate. Jegs sells GM Performance parts as well. I'm not sure that the PM rods can be reconditioned. Anybody? The caps are "cracked" when the rod is made. Literally broken apart, and then the ridges and valleys fit back together. I don't know that the mating surfaces can be ground smooth and then resized. Check with your machine shop. You may just want to use rods as-is, just replace the rod bolt nuts.
EDIT: Scoggin Dickey,http://www.SDPC2000.com has the lifter kit for $199.
But I do have the PM rods in my stock engine right now right? The reason I said I was going to recondition them is because I saw some on ebay that said they were reconditioned and fitted with ARP bolts. Should I do anything else to them besides use ARP bolts? bonk.gif
Guy
If you are not running over 6500 rpm, I would just replace the nuts when you reassemble the motor. If you are going to be running high RPM a lot, you should buy aftermarket rods and at that point I would go 6" as well. But then since you have to buy pistons and rods, might as well go for the 3.75" stroke crank... See where this gets you, don't ya'? (Deeper and deeper in debt!) Also, Scoggin Dickey has the COMP roller lifters for factory roller equipped motors for $179. And they have a part # HT-2148 OEM replacement '87 and up roller lifter for $7.50 each whether that's right or not I don't know...
Just the NUTS, not the bolts. Replacing the bolts can distort the bore of the rod. The bolts can be re-used, but the nuts cannot. (Should not at least, but it is done.) Hopefully someone else will pipe-in on the feasability of rebuilding the PM rods. Darn new-fangled stuf...
Eesh, that sucks. I may know someone that'll have them if Comp isn't making them currently (production runs have varying times).
Anyway, these are called anti-pump up lifters, so for $10-$20 more than regular lifters, I figure it was worth it for me smile.gif
Hope you can get em.
