Poundz9oh9 Posted September 8, 2004 Share Posted September 8, 2004 Their supposed to be Trick Flow, but I don't know anything about them. I looked at the Trick Flow site and they looked nothing like anything I saw there. Any help is appreciated guys. The only #'s I can find on these things is "SN 3305" and either S94, S84 or 694 or something to that effect is stamped in them poorly. Reallllly hard to read. HElp me pleeeease!! I know nothing specific on these things, and If I need to get a short block I need some specifics. Thanks Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 8, 2004 Share Posted September 8, 2004 Closest thing I can find is: 330545.....1973......350..........76cc chamber, 2.02/1.60 Quote Link to comment Share on other sites More sharing options...
Poundz9oh9 Posted September 8, 2004 Author Share Posted September 8, 2004 Trickflow??? Oh, and where'd ya get that info from ??? Quote Link to comment Share on other sites More sharing options...
A. G. Olphart Posted September 9, 2004 Share Posted September 9, 2004 They look to me like they may be Trick Flow-- the valves are canted, and the rocker bosses are therefore not in a straight line. Not your garden variety Chebby head. May require special pistons? Did some of the early Trick Flows have problems? Quote Link to comment Share on other sites More sharing options...
Mike C Posted September 9, 2004 Share Posted September 9, 2004 To the best of my knowledge, Trick Flows are about the only canted valve small block head. They were called Twisted Wedge. They used stock pistons. Are supposed to flow pretty well, but I had heard rumours of early failures. Quote Link to comment Share on other sites More sharing options...
Z-TARD Posted September 9, 2004 Share Posted September 9, 2004 "Twisted Wedge" perhaps? I haven't seen them advertised for a while, but Trick flow used to make some heads with that name a few years ago. Mike Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted September 9, 2004 Share Posted September 9, 2004 I have those heads! Trick Flow G-2 twisted wedge (23 degree). They produce great power. The only thing that you need that is different is the pushrods, they need to be checked, and custom ones made. Quote Link to comment Share on other sites More sharing options...
Poundz9oh9 Posted September 9, 2004 Author Share Posted September 9, 2004 Thanks alot, you guys are great! I think I found most of the needed information on an internet search. Knowing the model really helped alot!! Quote Link to comment Share on other sites More sharing options...
jt1 Posted September 9, 2004 Share Posted September 9, 2004 I've got a set of those, they are nice heads that perform well. Because of the canted valves, it's important that the valvetrain geometry be right on the money or you will eat the valve guides quickly. It takes special lenght pushrods and a different lenght for the intake and exhaust. Comp makes a set of roller rockers with offset fulcrums that makes it a lot easier. The early TW's had iron valve guides in them, and that combined with incorrectly setup rockers caused some problems. My 355 w/those heads made 330 at the wheels. John Quote Link to comment Share on other sites More sharing options...
Guest Blazer406 Posted September 17, 2004 Share Posted September 17, 2004 I also have a set of the original twisted wedge heads. They are decent street heads for the money. I have them on a 9:1 350 in a heavy S10 Blazer (3950# with driver) and with a very mild cam have gone 13.13 on DOT approved tires. I estimate mine makes about 325-330 hp at the wheels too. I had to have my valve guides replaced with bronze ones. No problems since though. Quote Link to comment Share on other sites More sharing options...
