heads (closed chamber vs open chamber)
Guest Anonymous
Guest Anonymous
does anyone know the diffrence between an open chamber head vs a closed chamber head? i was looking on the afr website into 68cc 195 heads. upon e-mailing them for more info i found out i cannot use 68cc heads as they have a closed chamber and i have .100 dome pistons. they told me i could use there 74cc heads milled to 68cc as they are open chamber heads. will a open chamber head make the same power, or more, or less, what really is the diffrence? besides an open chamber allowing the use of a dome piston.
Guest Anonymous
yep AFR 195 heads. and the pistons are trw .100 dome part#2304. they at AFR said there 68cc heads will not accept dome pistons. only flat tops or dish pistons. will a open chamber head make the same power as a closed chamber? or should i find a closed chamber head that will accept the .100 dome pistons? really like the flow numbers of the AFR'S.
It is a general way of classifying heads, but there is some science to it. With GM heads, there are two different combustion chamber designs, the open (76cc) and closed (64cc) [note this is all based on old stuff as you have 58cc heads for 305's and L98 aluminum heads and some variations as well.] David Vizard says all things being equal, the closed chamber is worth 20 hp. Remember, all of this is in discussing GM production heads. Limited production (Bow Tie) and aftermarket heads throw out all of the rules. If you have bought all of your parts, I would have the dome knocked off the pistons (the difference between the 1970 and 1971 LT-1s) and have the heads angle milled and the intake re-aligned to achieve whatever compression is your goal.
