Phantom Posted September 30, 2004 Share Posted September 30, 2004 This is a new one for me. 1993 Z32 convertible. Both turn signals function normally until the head lights are turned on. Then the right turn signal behavies normally and the left turn signal flashes at about double the normal speed - almost like what you would see with one of the bulbs burned out - except they're not and both front and reart signals are flashing - at twice normal speed. Turn the headlights off and it goes back to regular speed. Again - this only happens on the driver side - not on the passenger side. Go figure. Quote Link to comment Share on other sites More sharing options...
innerware Posted September 30, 2004 Share Posted September 30, 2004 Check to see if the intensity is as bright in all the bulbs. Sometimes a bulb will only half go. So when you have your lights turn on it wants to burn brighter and use all its filaments. So, during the day it doesn't blink fast since the turn lights aren't as bright. Something like that but I have seen it before. Quote Link to comment Share on other sites More sharing options...
dmyntti Posted September 30, 2004 Share Posted September 30, 2004 Try checking the ground on that side. Your running lights might be grounding through the turn signal. Quote Link to comment Share on other sites More sharing options...
DaleMX Posted October 3, 2004 Share Posted October 3, 2004 Try replacing the bulb (filament might be broken and touching the other filament). Then check everything else if that doesnt work. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted October 3, 2004 Share Posted October 3, 2004 I have seen the multifunction switches on other makes of cars do stuff like this. I cant explain why but I have seen it. I also agree to check the bulbs first and replace if at all in question. Guy Quote Link to comment Share on other sites More sharing options...
Phantom Posted October 4, 2004 Author Share Posted October 4, 2004 Since I don't know if the problem resides in the front or the back - and since my wife does most of her driving in daylight where the signals work fine - I'll probably just wait a while and see if one finally burns out and then replace it. Thanks for the input guys. Some thoughts there I hadn't had yet. Quote Link to comment Share on other sites More sharing options...
