Must speek with L28 into 260Z people about tach wiring
THUNDERZ
I put an 82 L28 into a 74 260Z Manual trans and using dizzy from the 82. My car runs fine but havent had any tach action sinse the swap.I am trying to figure out what wires to hook up to make my tach work again. I have wiring diagrams but they dont sem to help with this. Anyone who has done it please shoot me some advic :roll: e.
Is the 260 tach the same as a 280? (I thought it was just the 240's that were different) If so, I can go look at my 280 and get you the wire colour/locations. Im running a zx dizzy as well. I had evrything discombooberated and had to figure out all the wiring when I got my car done this past spring.. IIRC, I just ran a jumper wire from the + batt and touched the wires (there's likt 5 in a bunch by the coil) till the tach jumped.
Your 260Z tach needs a “trigger” connection to the negative side terminal of the ignition coil. This is done via the solid blue colored wire that was part of the 260Z’s ignition coil wiring harness. Check for this.
BTW, what coil are you using? 260Z or the ZX one?
