v8dats Posted January 28, 2003 Share Posted January 28, 2003 can u swap out an intake from an lt1 to a tpi?and still use the tpi comp?just a thought Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 29, 2003 Share Posted January 29, 2003 No. Quote Link to comment Share on other sites More sharing options...
zgeezer Posted January 30, 2003 Share Posted January 30, 2003 Well actually you can swap an LT1 intake onto a small block chevy. Take a look at lt1intake.com Requires some work, but looks good. gw Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 30, 2003 Share Posted January 30, 2003 I thought about posting that as well zgeezer, but I read and re-read his post and couldn't tell which way he was going! Quote Link to comment Share on other sites More sharing options...
Sumo Posted January 30, 2003 Share Posted January 30, 2003 How about this, can you just forget the FI and go carb on the LT-1? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 30, 2003 Share Posted January 30, 2003 that seems like you would be going backwards. I think the heads are the same pattern as a standard manifold like a performer or somthing arn't they? just my .02 Quote Link to comment Share on other sites More sharing options...
Guest Drewz Posted January 30, 2003 Share Posted January 30, 2003 Yes they do make manifolds for crossing over. Quote Link to comment Share on other sites More sharing options...
Guest Bob L Posted January 30, 2003 Share Posted January 30, 2003 You may want to check out the TPIS miniram2; it works with the normal small block heads and is very similar to the LT1 intake. The only downside is that it's expensive, around $1K www.tpis.com Quote Link to comment Share on other sites More sharing options...
Mike C Posted January 30, 2003 Share Posted January 30, 2003 I bought a carbureted intake for my LT1. I actually have two LT1s, but only enough parts to FI one. I plan on getting my car running with the carb and fuel inject it later. Then I'll use the carb intake on the second motor. In 1997 GM built a couple of 302 ci LT1. One in a replica 1967 Z/28 with the carbureted intake and one in a 1997 Z/28 with FI. Both cars had T56. Don't remember the exact details, but the carbureted car made nearly 50hp MORE than the FI car. Quote Link to comment Share on other sites More sharing options...
Mudge Posted January 30, 2003 Share Posted January 30, 2003 Its been done, I think www.lt1intake.com is the site, may be costly though. Basically they just machine the rear of the intake for the distributor, I dont think there is anything complex other than the accuracy. The LT1 heads have also been used on SBC before, and SBC heads been moved to LT1, with machine work of course in both cases. Quote Link to comment Share on other sites More sharing options...
Mudge Posted January 30, 2003 Share Posted January 30, 2003 Originally posted by Mike C:Don't remember the exact details, but the carbureted car made nearly 50hp MORE than the FI car. It would be nice to know if that was RPM or what, because past 7k the stock PCM basically wont run, there are always reports of ringers doing 7100/7200 but who knows. Quote Link to comment Share on other sites More sharing options...
Mudge Posted January 30, 2003 Share Posted January 30, 2003 Originally posted by Bob L:The only downside is that it's expensive, around $1K www.tpis.com This is why I would not start with an L98 The LT1 is a nice middle of the road between the 80s Chevy V8s and the LS1/6, which is still too expensive for me. Quote Link to comment Share on other sites More sharing options...
