Mike C Posted January 30, 2003 Share Posted January 30, 2003 If the assembly was balanced to the current balancer, just have the new one balanced to match the old one. Check out these CAT balancers. The SFI steel one is less than $100. http://www.catpep.com/Products.htm Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 31, 2003 Author Share Posted January 31, 2003 That`s what I was wondering. I was hoping they could balance one to match another without having the entire rotating assembly. Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 31, 2003 Author Share Posted January 31, 2003 The 383 that I have was already assembled when I bought it. It has already been balanced. Now the problem, The engine has a stock gm harmonic balancer on it. I want to change to an sfi approved balancer, possibly a fluid dampener. Are the balancers typically weighted differently? Could I take the balancers to a machine shop and have them balanced to match? Or, will I have to have the entire rotating assembly rebalanced? I`ve never had this dilema before. I`ve always taken everything to the shop and picked it up when it was done. I would rather be safe than sorry. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 31, 2003 Share Posted January 31, 2003 Re-balance the entire assembly. Like you said...safer. Also it gives you the opportunity to plasti-gauge the bearing clearances to check if the assembly was done correctly. Tim Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 31, 2003 Author Share Posted January 31, 2003 The engine was assembled by one of the most reputable shops in the area, so my concerns otherwise are minimal. I just didn`t want to tear the whole thing down if I didn`t have to. As it sits, all it needs to run is a the carb and distributor. DAMNIT Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 31, 2003 Share Posted January 31, 2003 Denny, No one is perfect all the time. If you have it apart, check the clearances. You'll have piece of mind. Tim Quote Link to comment Share on other sites More sharing options...
denny411 Posted January 31, 2003 Author Share Posted January 31, 2003 I might as well throw some forged 11:1`s in while I`m at it, and since the heads will be off, I guess I should pick up some aluminum Pro1`s. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 31, 2003 Share Posted January 31, 2003 yeah....while you're at it Tim Quote Link to comment Share on other sites More sharing options...
