name your clutch
evildky
Guest Zcarsmakemyheadhurt
I got a stage V CM on Mikes car, with a Fedenzia flywheel and a 6 puck. Same combination I had on my ZX and I like it alot, so far. On a budget I would do a 86 turbo plate and 6 puck bronz, I personally have never had any success with organic disk on my L28 cars.
I will certainly change out the PP if this thing starts to slip. However, I have several months before Im making the 500whp ;)
I can't wait for the ringlands to break because of power. That's just fun.
I will certainly change out the PP if this thing starts to slip. However' date=' I have several months before Im making the 500whp ;)
I can't wait for the ringlands to break because of power. That's just fun.[/quote']
Your my kind of dude :twisted:
:lol: Everyone here thinks Im nuts for even considering 20psi on stock turbo.
When I put down 324tq @ 3000rpm everyone was stuned. All I heard from everyone was "WTF?!" and "Holy crap that thing got up and went on the dyno!". It was fun. I wish I could've gotten a clean run when I made the 399wtq the other week. This weekend I hope to be able to run constant 20psi. I'll bring it back, and maybe I'll get in the 300whp club. On stock turbo, it's pretty rare.
You've just made my ears prick up here. I didn't realise the PP from a Z31 would fit on the L flywheel, mainly 'cos I know nothing about clutches. I've just got hold of a Z31 to break, grabbing the T5 box out of it for my 240Z. If I get a 240mm flywheel would I also be able to use the friction plate from a Z31 turbo?
At the moment I've only got a very asmatic 2.4 but plans are well underway for a 3l stroker so I'm going to need a decent clutch system at some point.
Cheers,
Rob
ok i bought a CF DF for my turbo swap but im running the N/A flywheel should i buy a new disk maybe even a stock one?? all this anti cf talk has got me scared. Is the PP still good? oh my what shall i do?
relax, while the thing wore wierd, turns out I had the worng throwout collar on the trans, I used the one that came with it and it's the shorter one, I just got the longer one, also I abuse mine pretty bad, it's a race car, it sees very little if any street use and when it does see the street I keep doing smokey second gear burnouts, I also am using the 225mm setup for lack of locating the larger flywheel, but I'd say the limits of the CFDF are not what I expected especially after some of the responces in this thread
Guest bastaad525
Just an opinion cronic, i would change out to a stronger PP if you're going to pull the trans. I think the most important factor on slippage, or lack of, is not the disk or the flywheel, it's the clamping force of the PP. Good luck.
agree 100%. Hence why you can get away with an organic disc just fine by using a stronger PP, and get all the benefits of the stronger clutch with none of the drawbacks of the metallic ones.
The thing is, the stock PP has a LOT of clamping force. The metallic will help to keep it from slipping. If need be, I will upgrade the plate later. Which is only a 4 hour job. I took the car out last night for a brisk few runs, tryin to dial in the a/f, the clutch did a good job at 22psi (leveling off to 18.) and 140mph.
I think she's doing her job. This may just be a case of "different strokes for different folks". :dunno:
