Wide Cobra Wheels or Equivelent
I am planning on the 5 lug swap and need wheels that are wider than what I seem to be able to find conventionally. Besides custom (expensive) wheels does anyone know where I can find 18" x 12" even 13" 5 lug. If I have to buy custom wheels i will probably forego the 5 lug as it would be pointless. Thanks for the help!
Rufus
Uh that one is gonna be hard. THe widest I've found the Cobra Rs is 10.5. I've been keeping an eye out for a serious deal on some light weight 17X9 and 18X9s on Ebay and I've not seen any wider than 10.5 in the 6 weeks I've bee searching!
Mike 8)
Guest DiZeased_240
There are plenty of options available for the Cobra 5-lug pattern. The problem with most of them is the offsets that are available, especially if you want to go wide. Spacers are a must unless you do a custom build. That's the route I'm taking, probably CCW's.
If you stay with the stock 4-lug I think you will most likely have to go custom if you want the width and size you described. I haven't seen any options that large out there, maybe someone else has and could chime in.
If you want wheels in a low or negative offset, id recommend checking the the for sale section of
http://www.zilvia.net
http://www.ziptied.com
http://www.takumiproject.com
On zilvia ive seen some 18x12 with a -12 offset (would requite possably widebody) and 18x11 in front for 1200$, which is a steal IMO, 5x114.3
Again these are quite agressive offsets and widths, you might needs the YZ (iirc) Wide body to run these, Im not sure a normal 30mm ZG flaire will cover it.
