ZTR Posted November 16, 2004 Share Posted November 16, 2004 i was looking at crate motors on sdpc2000.com an i saw a 345hp 6.0L Gen III Escalade Crate Engine. the only thing i can see wrong with using it for a swap is it's a cast iron block so i would think it heavy. but i dont know give me your thoughts. Quote Link to comment Share on other sites More sharing options...
Guest DiZeased_240 Posted November 16, 2004 Share Posted November 16, 2004 It shouldn't be any heavier than any other small block V8 cast iron block that someone is putting in a Z. Is there some reason you are interested in that motor versus one of the other crate engines available? If you just want the Cadillac engine for something different you might look at the 4.6L Northstar. It has 320 horsepower @ 6400 RPM and 310 lb-ft of torque @ 4400 RPM. It is $500 more but you also will be a little lighter because it has an aluminum block. Quote Link to comment Share on other sites More sharing options...
ZTR Posted November 16, 2004 Author Share Posted November 16, 2004 no,,,, i dont care if it a Cadillac engine. i have been looking gen3 builds in car craft and they seem it build good power for pretty cheap if you know of another gen3 motor i would like to hear some ideas Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted November 16, 2004 Share Posted November 16, 2004 You might want to look for a 6.0L Gen III from a 3/4 or bigger Chevy or GMC Truck. I believe they are the same as the Escalade motors, and you may can get a complete truck to grab the harness and computer from. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 16, 2004 Share Posted November 16, 2004 A recent Hot Rod (I think) magazine had a guide to LS engines and the escalade motor is suppose to have LS6 like heads. I think this is different from the regular 6L truck engines. I will look at the article again once I get home. The magazine also detailed an LS crate engine install. The crate package came with a computer especially set up for non-stock installations. Good read. The Northstar has been talked about quite often. Expensive to work on and doesn't have the aftermarket support of the LS engines. Quote Link to comment Share on other sites More sharing options...
maichor Posted November 16, 2004 Share Posted November 16, 2004 LS1 if you are ready to build now. But, since you are looking at crate motors and more$ for them, just start looking around for the LS2. You can get the larger displacement you are after. You may have to wait a while to pick up an LS2 crate motor. I would drop in a used (read cheaper) LS1, drive it couple years and then pick up LS2 short block. I can't wait to see the real numbers for the output on the C6 Z06 version of the LS motor. By the way, the '01 and '02 LS1 can be rebuilt once without resleeving. If you have one of those, you could do a lunati stroker kit and still be about the same price wise. However, if you have someone build a stroker for you look for big$ on an LS1 $10-15K. So, I still say LS1. If you want, add a 100 shot for $500 and you are still under budget. Quote Link to comment Share on other sites More sharing options...
ZTR Posted November 16, 2004 Author Share Posted November 16, 2004 i have seen ls2 blocks for sale but nothing else. the 6.0l was just a idea i think it would be would be a nice motor. i think???? Quote Link to comment Share on other sites More sharing options...
mas28O Posted November 16, 2004 Share Posted November 16, 2004 Here are the November specials. Next month (December) we will be running THE best special on GM parts, EVER, on EVERY GM part. It will be dubbed "Christmas @ FredBeans". I am also introducing a specials email list where when I have my specials ready to post or I want to give all of those people on the list something special they can get it. If you would like to get on this list, especially for the "Christmas @ FredBeans" please email me at gculley@fredbeans.com with your name and specials list as the subject header. At any given time for any given reason you may request to be taken off the list and immediately be taken off. Stay tuned!! ||--All New LS2 Items!--|| LS2 Engine Block - 916.50 + Actual Shipping Charges! LS2 Throttle Body (90mm) - 249.99 Shipped To Continental US! LS2 Long Block - 5499.00 Shipped To Continental US! ||--Genuine GM LS6 Intake Manifold--|| 88894339 - Intake Manifold Only - 389.99!! 88894339 - Intake Manifold W/Coolant Pipes And Plugs - 429.99 Shipped To Continental US!! ||--Genuine GM UltraGuard UPF 44 Oil Filters--|| 25329389 - UPF 44 Oil Filter Must Order In Case Of 6 Only! Case Of 6 Shipped 45.99 To Continental US! ||--Genuine GM Cylinder Head Bolts And Gasket Kits--|| 12498543 - 97-01 LS1 Engine Head Gaskets (2) - 37.25 Shipped To Continental US! 12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) - 28.99 Shipped To Continental US! 12498545 - 97-04 LS1 & LS6 Engine Head Bolt Sets (2 Cylinder Heads) - 43.99 Shipped To Continental US! ||--Genuine GM GTO Fuel Rail Covers--|| LH & RH Fuel Rail Covers 89.99 Shipped To Continental US! Availability Is Limited And Will Apply When Ordered! ||--Genuine GM Clutch Parts--|| 12570806 - '02 Fbody And Corvette Z06 Clutch - 369.99 Shipped! 15046288 - '98 -'02 Fbody Slave Cylinder -106.80 Shipped! 12570277 - '01 -'02 Fbody Master Cylinder - 123.80 Shipped! ||--Helms Service Manuals--|| '98-'02 Firebird And Camaro - 124.95 Shipped To Continental US Please Call For Any Other Make/Model Vehicle! ||--Genuine GM GTO "5.7" Emblem--|| 92119040 - GTO "5.7" Emblem - 26.99 Shipped To Continental US! ||--Genuine GM Performance Parts C5R (427) Block--|| 12480030 - C5R (427) Block - 6300.00 Shipped To Continental US! ||--Genuine GM 405HP LS6 Crate Engine--|| 12498399 - Comes With FBody Oil Pan For You Fbody Folks! 5229.99 Shipped To Continental US! ||--Genuine GM LS1/LS6 Engine Parts--|| 12455209 - '98 - '02 WS6 Lower Airbox - 78.50Shipped! 12551366 - 6.0 Litre Bare Engine Block - 639.95 12565308 - '02 LS6 Cam - 209.95 12586484 - '02 LS6 Valve Spring - 5.50 each 12564824 - '02 LS6 Cylinder Head (Assembly) - 699.99 each 12564825 - '02 LS6 Cylinder Head (Bare) - 609.99 each 12480110 - ASA Racing Cam - 359.95 12480033 - LS1 Hotcam Kit - 419.99 88958622 - LS6 CNC Ported Cylinder Head (Assembly) - 959.99 each!! ||--Genuine GM Fbody Brake Parts--|| 18026298 - Front Brake Pads - 95.27 88899570 - Rear Brake Pads - 55.86 18038817 - GM Durastop Front Rotors - 69.95 each! ||--Genuine AC Delco Performance Drilled/Slotted Rotors (Corvette)--|| 88926732 - LH Front Rotor 88926731 - RH Front Rotor 88926734 - LH Rear Rotor 88926733 - RH Rear Rotor Front and Rear Rotor Sets 212.99 Shipped To Continental US! ||--Genuine AC Delco Ceramic Brake Pads (Corvette)--|| 88909667 - Front Complete Set 88909668 - Rear Complete Set Front and Rear Ceramic Pads 117.50 Shipped To Continental US! ||--Genuine GM Performance Parts 6.0 Engine Assembly--|| 12499467 - 3699.00 Shipped To Continental US! Complete 6.0 Engine Assembly With Intake Manifold, Exhaust Manifolds, Fuel Rails, Etc.. 345 HP@ 5200RPM ||--Genuine GM Corvette Z06 Brake Calipers--|| 88895128 - LH Front Caliper 88895129 - RH Front Caliper 88895130 - LH Rear Caliper 88895131 - RH Rear Caliper Both Front and Rear Caliper Sets 349.99 Shipped To Continental U.S! ||--Genuine GM OEM Corvette Rotors--|| 10445856 - Right Front Rotor 10445857 - Left Front Rotor 10445858 - Right Rear Rotor 10445859 - Left Rear Rotor Front and Rear Rotor Sets 258.99 Shipped To Continental US! ||--Genuine GM 2004 Corvette Z06/Z16 Shock GP--|| 10339944 - Front Shocks 10339945 - Rear Shocks 345.99 Shipped To Continental US! ||--Genuine GM Corvette Z06 Stabilizer Bar Kit--|| 10419094 - Front Stabilizer Bar 10424743 - Rear Stabilizer Bar (2) 10351954 - Front End Links (2) 10351954 - Rear End Links (2) 10419095 - Front Bar Insulators (2) 10333410 - Rear Bar Insulators 231.99 Shipped To Continental US! ||--Genuine GM WS6 Emblems--|| 88951585 - Black "WS6" Emblem - 59.97 12455216 - Red "WS6 Emblem" - 79.97 12458777 - Blue "WS6 Emblem" - 69.97 ||--Block Off Plate Kits--|| EGR Block Off Plate And Gasket - 14.80 A.I.R Block Off Plates And Gaskets - 19.80 EGR-A.I.R Block Off Plates And Gaskets - 29.80 ||--Genuine GM LS1/LS6 Fuel Rail Covers--|| 12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering) 12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering) Both 54.99 Shipped To Continental US! 12561503 - '99-'02 LH Fuel Rail Cover (Black with Red "Corvette" Lettering) 12561502 - '99-'02 RH Fuel Rail Cover (Black with Red "Corvette" Lettering) Both 63.99 Shipped To Continental US! 12564257 - '01-'02 LH Fuel Rail Cover (Red With Black "Corvette" Lettering) 12564258 - '01-'02 RH Fuel Rail Cover (Red With Black "Corvette" Lettering) Both 90.50 Shipped To Continental US! Fred Beans Pontiac Buick GMC Terms And Conditions Of All Sales: We reserve the right to change the price of any part at any time and/or refuse to sell a part for any reason at any time. Price changes that can be made through the month are final and all sales before and after the price change are final. We will accept no returns after 30 days and all boxes or packages must be in the same condition as which they were received. If a package is received in anything other than perfect manner, please call and note upon receipt. Anything noted after the fact is the responsibility of the buyer. All returns are subject to a 20% restocking fee and/or a fee for unacceptable boxing or packaging. We reserve the right to change the terms and conditions of a sale at any time for any reason. __________________ Fred Beans Pontiac Buick GMC gculley@fredbeans.com or 610.495.1700 Quote Link to comment Share on other sites More sharing options...
Calico Posted November 17, 2004 Share Posted November 17, 2004 mas28O-hey I think I'll be lookingin to your company for parts...prices seem good...do you have a website? also how much do you offer these 2 parts for? 1LE / AC Delete pulley GM Partsdirect PN# 10055890 $38.15 + S&H A.I.R. / Smog pump Delete pulley GM Partsdirect PN# 10186167 $35.22 + S&H Quote Link to comment Share on other sites More sharing options...
chopstic Posted November 17, 2004 Share Posted November 17, 2004 i was also looking into the gen III 6.0l, looks like a nice crate engine for less price than the ls1. Claims to only be like 65lbs heavier than an ls1 which still makes it a pretty light engine. it doesn't look like it comes with any of the electronics, how much would you guys estimate it would cost to aquire the electronics to get this thing running?? Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 17, 2004 Share Posted November 17, 2004 The December issue of Car Craft has half the issue devoted to LS engines. They dyno a $6200 LS1 crate engine, complete with ECU, that made 402 HP out of the box. Only needed a half dozen items to complete the engine (they gave the part numbers). They also have charts detailing exactly what head came on each engine. The Escalades have an LQ9 engine whose head is based on the LS6 head. Said these heads work better for blown applications. They also detail a stroker kit that put displacement at 402 Cubes and made (I think) 580 HP. Very expensive though. Quote Link to comment Share on other sites More sharing options...
Guest ALL UC2 Posted November 21, 2004 Share Posted November 21, 2004 the aluminum headed escalade motor would be a great choice. it has the same heads as a ls6/ls2 except has bigger combustion chambers. throw a bigger cam and valve springs in it the i would say you would be pushing 400 hp to the wheels. i have seen dyno charts on the 5.3 truck motors where they put a cam and headers on the motor, nothing else, and gained 103 hp over stock. WITH JUST A CAM AND HEADERS!!! Quote Link to comment Share on other sites More sharing options...
