80LS1T Posted January 4, 2005 Share Posted January 4, 2005 I started to delete the unneccesary stuff from my 95' LT1 harness tonight. So far its going great. With the help of ALLDATA online this is going to be a cake walk! They pretty much give you a diagram for what the engine needs to run and what is needed for A/C, emissions, guage sensors(for a stock LT1 TA....I have my own guage sensors) and other nonessential stuff. Im glad I didnt buy a painless harness for like $600! I still have to buy a data link connector and a pair of O2 sensors for sure. I wont know if the sensors I have on the engine now are the same as the 95 till I get the harness test fitted on it. So how much is the TunerCat software? I see a lot of different prices on their site but I dont know what I need? Tim? Mas280? Thanks, Guy Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 4, 2005 Share Posted January 4, 2005 IIRC, the software is ~$80, and then you need the correct definition file ($EE, I think), which is another $20. As for the harness, I too wonder why folks pay the ridiculous $$$ for the aftermarket harnesses...... Don't forget to download freescan and get a connector from Andrew (links on Tunercat's site). Also, the OBDI DLC connector can be grabbed from any GM OBDI car at the JY. I got mine from a cavalier. Tim {edit}Tuner software is $69.95 and the definition file is $19.95 Quote Link to comment Share on other sites More sharing options...
80LS1T Posted January 4, 2005 Author Share Posted January 4, 2005 So what is that $850 package all about? And what are deffinition files? Thanks, Guy Quote Link to comment Share on other sites More sharing options...
Tim240z Posted January 4, 2005 Share Posted January 4, 2005 The definition files are the specific vehicle software (TunerCat Tuner being the main software). The expensive package is for shops that want to be able to tune every vehicle that TunerCat supports Quote Link to comment Share on other sites More sharing options...
hanomon Posted January 4, 2005 Share Posted January 4, 2005 If you don't mind soldering or splicing a few lines 3 or 4, I'll send you an extra DLC out of an IROC. I believe it was a 95' Quote Link to comment Share on other sites More sharing options...
80LS1T Posted January 5, 2005 Author Share Posted January 5, 2005 I just emailed you hanomon. As long as its an OBD1 type connector I'll take it! Thanks for the help Tim on the Tunercat questions! Guy Quote Link to comment Share on other sites More sharing options...
wheelman Posted January 5, 2005 Share Posted January 5, 2005 Has anyone tried using a standard 9-pin serial port connector? I have the DLC from the donor car but I'm also going to connect a 9-pin serial connector to the communication lines of the PCM so it's easier and cheaper to build a cable for the laptop. I'm not sure whether I'm going to use TunerCat or LT1 Edit, which do you guys like better? Wheelman Quote Link to comment Share on other sites More sharing options...
Bartman Posted January 5, 2005 Share Posted January 5, 2005 With the help of ALLDATA online this is going to be a cake walk! They pretty much give you a diagram for what the engine needs to run and what is needed for A/C, emissions, guage sensors(for a stock LT1 TA....I have my own guage sensors) and other nonessential stuff.What is 'ALLDATA online'? I'd like to see the diagram for my 94 LT1. Quote Link to comment Share on other sites More sharing options...
80LS1T Posted January 6, 2005 Author Share Posted January 6, 2005 ALLDATA is like Michele or Chiltons. Its an online service manual basically. You pay $25 per year for the first vehicle you subscribe to then its $15 for every vehicle there after just as long as you keep 1 supscription up to date. Otherwise you start over with the $25 first vehicle fee. Its really a great manual if you ask me. I personally hate Michele's manual. Its very easy to use and they have very good wiring diagrams. Heres the link.... http://www.alldata.com/ Go to the "DIY" links. wheelman, I wouldnt see why you couldn't use a 9 pin serial connector? If you never plan to hook it up to a standard scanner then I would say thats the way to go. Guy Quote Link to comment Share on other sites More sharing options...
