Is fuel pressure supposed to drop?
z_boi
I have an aeromotive A1000-6 FPR and a jsk fuel rail. My fuel pressure drops when i rev the engine. Is that supposed to happen? I also jus changed the pump to a higher flow bosch pump and it still does the same thing? ( pump flows 50gph which is about 190lph and 100 max psi ) whats stock pressure supposed to be? this if for a 78 280z.
Guest 81na ZX
Do you have it referencing vaccum? I have that AFR in my DSM, and if you have a vac line going to the top port, and are creating a vac, FP will go down. That reg will increase pressure 1 psi of fuel for avery 1 psi of boost... or decrease it for every "psi" of vac.
How much does it drop? Every regulator has limited compliance, so they all vary somewhat.
That FPR will reference fuel pressure to manifold pressure on a 1:1 basis (1 pound of MAP change = 1 pound fuel pressure change. If there is vacuum in the manifold, fuel pressure will decrease from the base setting (atmospheric = vacuum reference hose disconnected) , With positive MAP, fuel pressure will increase.
