Guest JAMIE T Posted January 16, 2005 Share Posted January 16, 2005 My mounts came in today. Now, I need to figure out who to get the Supra mounts from. I think autozone can order them for me. BAP/GEON, can't even get them which was huge surprise to me. They have everything for all imports. I still find it odd that he used such an odd isolator for these. He could have used anything. The news is ATI makes a Super Damper for RB26's. I'm gonna call Monday and get the skinny. The website shows about 6 differant part numbers and it's kind of confusing. So, I'm gonna call them and see what's what. I also emailed Eagle and told them they should make rods for RB26's. I haven't gotten a reply. That was about a week and a half ago. I like the idea that US performance manufacturer's are taking the time to make parts for such a small market engine. Quote Link to comment Share on other sites More sharing options...
AKWIKZ Posted January 16, 2005 Share Posted January 16, 2005 Funny that you mention the ATI damper, I just bought one. They make a direct replacement one and a race version. After talking with them a while, I opted for the race one. My motor will be putting down a minimum of 500hp and be spinning at close to 9 grand. If you go for the race one, you will need to decide how many components you will be running. The super damper does not have and serpantine pulleys on it stock, you will need to instruct them on your needs. I only needed the one pulley, for the water pump and alternator. They put on a Chevy six groove pulley. The RB uses a four or five groove I can't recall at the moment. This is not really a big deal. With my SR20 powered Roadster, I had a similiar situation. I found that just making sure the belt tension was right kept it from ever jumping off. Now, that said, the damper is absolutely awsome. The quality is top notch and the instructions are clear. Of course quality is not cheap. My damper cost a bit over $450 delivered, so keep this in mind. Brian Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted January 16, 2005 Share Posted January 16, 2005 Engine longevity is priceless... $450 is a drop in the bucket when considering how much it would cost if you trashed a crank or block do to relying in stock parts on a race motor. I'm gonna just be running an alternator and waterpump also. Though I do plan on seeing if CSI will make a pump an electric pump. What is the differance between the OE replacement and the race version? With either one, does the engine need to be re-balanced? So, are you going to be using a GM 1 wire type alternator with a serpentine drive? Quote Link to comment Share on other sites More sharing options...
Zhadman Posted January 18, 2005 Share Posted January 18, 2005 My Infinity Machining mounts came in today. In case anyone is wondering... this is what they look like: A guy I know installed an earlier set on his RB25 and had to do some trimming to clear the forward oil return line. This set appears to have a relief already incorporated. We shall see tonight! Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted January 18, 2005 Share Posted January 18, 2005 yes, they do appear to have the notch already done. I had to take off that material to get it to clear the oil pipe as you said. that was the only issue I had with using them. now they are 100% puss..... Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted January 18, 2005 Share Posted January 18, 2005 Joel... I was thinking about your mounts when I was unwrapping mine this weekend. It was hard to see in your pics what you actually had to do for clearance. Thanks for letting us know that these (and mine) are clearanced already. I'm gonna get mine anodized with some other parts for corrosion resistance and long lasting beauty:) FWIW, I ordered my ATI balancer today. Should have it in a week or so. They are only a state away, but they need to build it. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted January 18, 2005 Share Posted January 18, 2005 For those who don't understand what we are refering to, look at my mount in this pic below. The mount needs to be strait up and down, not cocked to the right at the bottom. I was not able to move the bottom of mount over because of hitting the oil drain pipe, so I cut a L shape out of it for clearnce... problem solved... Quote Link to comment Share on other sites More sharing options...
AgentZ Posted January 20, 2005 Share Posted January 20, 2005 Hey those look good, Anyone know if they do them for 280ZX? ' Cheers! Quote Link to comment Share on other sites More sharing options...
EZ-E Posted January 20, 2005 Share Posted January 20, 2005 I have to add as well they look gorgeous. Great looking part there. Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted January 20, 2005 Share Posted January 20, 2005 I just want to know where to get this mounts from? I'm building a 280ZX... Quote Link to comment Share on other sites More sharing options...
