Timing jump?
Working on a friends Z 81zxt. The timing is all over the place. Set it to 20 and it runs great,then 5 min later very bad(backfires and sputters)and the timing is off +/- 10deg or so. At that point you have to just turn the dist untill the car runs good, sometimes set to 30,40 or even 10deg. . We changed ecu and dist several times no change. You can actually watch the timing change; any ideas?
Guest tony78_280z
Umm.... timing chain? Ummmm... You got Vaccum advance in the dizzy? Is it working? Is it hooked up right? ummm... You SURE you got the dizzy in the right spot (not a tooth off) and tightend down? Well those are my ideas. Dang beats me though.
