JDM RICE Posted October 24, 2007 Share Posted October 24, 2007 lol, i just ordered these mounts and they're now $2.98 each! should be picking them up today at Advance Autoparts Quote Link to comment Share on other sites More sharing options...
synthtk Posted November 7, 2007 Share Posted November 7, 2007 lol, i just ordered these mounts and they're now $2.98 each! should be picking them up today at Advance Autoparts Just a FYI, be sure to check your oil pan clearance with these cheap mounts, I had them at first hoping to save some $$ but with my custom aluminum oil pan it hit the steering rack, I think you will be ok if you use a RB20 pan though. Quote Link to comment Share on other sites More sharing options...
JDM RICE Posted November 8, 2007 Share Posted November 8, 2007 Just a FYI, be sure to check your oil pan clearance with these cheap mounts, I had them at first hoping to save some $$ but with my custom aluminum oil pan it hit the steering rack, I think you will be ok if you use a RB20 pan though. I'm playing around with mounts right now seeing what would best fit my setup, but i think I need to order these Rick Wong mounts. As of right now, I'm using the stock L28 mounting brackets and mounts, but it sits the motor TOO LOW..lol The oil pan sits about an inch or so lower than the cross member. I'm gonna email them and see if they have any available. Quote Link to comment Share on other sites More sharing options...
synthtk Posted November 8, 2007 Share Posted November 8, 2007 It is hard to be disappointed with the Rick Wong mounts, they are beautifully made. Quote Link to comment Share on other sites More sharing options...
JDM RICE Posted November 9, 2007 Share Posted November 9, 2007 anyone know of any other contact info or anyone selling these mounts? I sent an email without any response from them Quote Link to comment Share on other sites More sharing options...
synthtk Posted November 9, 2007 Share Posted November 9, 2007 infinitymachining@shaw.ca is what I used to contact Rick Quote Link to comment Share on other sites More sharing options...
skyline240z Posted November 10, 2007 Share Posted November 10, 2007 I still make the alum mounts, I have two more pairs. If anyone needs them email me at wong218@shaw.ca Thanks Rick Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted November 11, 2007 Share Posted November 11, 2007 Well, here you go guys.... to all the ones posting " wish I could buy a pair of those mounts " or " anybody know how to get a pair of the Rick Wong mounts " this is your chance !! I have a set in my Z. If you want the best... forget the rest.... Quote Link to comment Share on other sites More sharing options...
SmogSUX Posted December 16, 2007 Share Posted December 16, 2007 Does he produce a transmission crossmember? Or what has everyone else done for that? Quote Link to comment Share on other sites More sharing options...
JDM RICE Posted December 18, 2007 Share Posted December 18, 2007 you're on your own as far as the tranny mount goes for those who already own these mounts... QUESTION: Where did the supra mounts and your shifter location come out to? the reason why I ask is because I actually ended up using the isolators from Parts America from a '60's Dodge. The bolts are offset allowing your to push the motor back even further-about another inch or so. With that said, my shifter is nearly dead in the middle. Are the Supra isolators offset as well? If they are not, then I would suspect the shifter would be a little forward eh? Quote Link to comment Share on other sites More sharing options...
getoffmyinternet Posted January 4, 2008 Share Posted January 4, 2008 According to the picture, the supra isolators are offset, but I have yet to buy a pair to prove it. Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted January 4, 2008 Share Posted January 4, 2008 According to the picture, the supra isolators are offset, but I have yet to buy a pair to prove it. They are offset - so you can rotate them and change the alignment/position of the engine. Q Quote Link to comment Share on other sites More sharing options...
synthtk Posted January 8, 2008 Share Posted January 8, 2008 you're on your own as far as the tranny mount goes for those who already own these mounts... QUESTION: Where did the supra mounts and your shifter location come out to? the reason why I ask is because I actually ended up using the isolators from Parts America from a '60's Dodge. The bolts are offset allowing your to push the motor back even further-about another inch or so. With that said, my shifter is nearly dead in the middle. Are the Supra isolators offset as well? If they are not, then I would suspect the shifter would be a little forward eh? The supra isolators are offset but not as much as the Dodge ones from what I recall. I ended up having to use the Supra ones due to oil pan clearance issues with the Dodge ones. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted January 9, 2008 Share Posted January 9, 2008 I ended up having to use the Supra ones due to oil pan clearance issues with the Dodge ones. Same here. When I first went on a search for off brand isolators (less expensive), I didn't think about the thickness being a issue, so when I passed the part number along to everyone, I hadn't tried them yet for oil pan clearance. My Thaggard pan didn't work with the Dodge pieces.... I had to fork out the big bucks on the Toyota ones. Quote Link to comment Share on other sites More sharing options...
JDM RICE Posted January 9, 2008 Share Posted January 9, 2008 The supra isolators are offset but not as much as the Dodge ones from what I recall. I ended up having to use the Supra ones due to oil pan clearance issues with the Dodge ones. I think my oil pan sits about 1/2 inch or so lower then the cross member if I remember correctly, but its been a while since I looked. so if the Supra isolators its less offset, this would put the shifter near the very front of the shifter hole wouldn't it? Mine is about 1/2 the way towards the center of the shifter hole with the Dodge mounts also, how much thicker are the supra isolators? Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted January 10, 2008 Share Posted January 10, 2008 the shifter is near the top of the shifter hole - with the supra isollator. As for thickness I cannot comment. Q Quote Link to comment Share on other sites More sharing options...
Z U L8R Posted January 10, 2008 Share Posted January 10, 2008 LOL , I felt left out so i ordered these mounts today for the 510, got em in my hands now, they're about half as thick as the ka24 mounts hahahaha GG@this thread Dave Quote Link to comment Share on other sites More sharing options...
getoffmyinternet Posted March 22, 2008 Share Posted March 22, 2008 FYI, the dodge isolators DID NOT WORK for me. It was quite impossible due to alignment issues. See why on my build thread here http://forums.hybridz.org/showpost.php?p=855609&postcount=102 Here are the final pictures of rick's mounts with the supra isolators installed. Nothing is ever exact but I'm quite satisfied. Quote Link to comment Share on other sites More sharing options...
JDM RICE Posted April 15, 2008 Share Posted April 15, 2008 FYI, the dodge isolators DID NOT WORK for me. It was quite impossible due to alignment issues. See why on my build thread here http://forums.hybridz.org/showpost.php?p=855609&postcount=102 Here are the final pictures of rick's mounts with the supra isolators installed. Nothing is ever exact but I'm quite satisfied. hmm, with that said, were the Supra mounts significantly easier to fit and offer a better OVERALL clearance? I know EXACTLY what you're talking about with the Dodge mounts. Quote Link to comment Share on other sites More sharing options...
mattyice Posted April 15, 2008 Share Posted April 15, 2008 i sent an email to rick and as of a month ago he is getting ready now to make another batch, anyone interested in them should email him Quote Link to comment Share on other sites More sharing options...
