cobraz240z Posted February 2, 2005 Share Posted February 2, 2005 Help I Just Replace My Head Gasket On My 1976 280z And It Wont Start It Has Spark I Check All The Fuel Lines And It Has Spark If I Put Gas Down The Maf It Will Run What Can It Be Quote Link to comment Share on other sites More sharing options...
PUSHER Posted February 2, 2005 Share Posted February 2, 2005 Hook a battery up to the gas pump under the car and try starting it. Random thought: I dont know whats worse, all caps or caping the beginning of every word. Quote Link to comment Share on other sites More sharing options...
GabeRoc Posted February 2, 2005 Share Posted February 2, 2005 or listen for the fuel pump to run when you turn the key... it does sound like a fuel or electrical problem. check your wires, check for fuel flow, make sure you're not leaking air after the maf... look for that thing you forgot to hook up. --gabe Quote Link to comment Share on other sites More sharing options...
PUSHER Posted February 2, 2005 Share Posted February 2, 2005 Im pretty sure you wont hear anything because a 280z doesnt prime like newer cars. Quote Link to comment Share on other sites More sharing options...
datsunlover Posted February 2, 2005 Share Posted February 2, 2005 Actually, my 280 did something before starting.. the pump would come on (and run continuously..) and there were 5-6 'clicks' from the engine bay.. not sure if this was normal though, as it had a failing FI system. Quote Link to comment Share on other sites More sharing options...
cobraz240z Posted February 2, 2005 Author Share Posted February 2, 2005 it has fuel pressure and its still not running help i don't know what to do Quote Link to comment Share on other sites More sharing options...
Tim240z Posted February 2, 2005 Share Posted February 2, 2005 Check all the electrical connections....I assume that the injectors are plugged in? Something in the engine bay is unplugged. Quote Link to comment Share on other sites More sharing options...
Guest 260ondubs Posted February 3, 2005 Share Posted February 3, 2005 My stock intank fuel pump did prime when I turned the key. It was very audible. So should your's... unless it has died. Quote Link to comment Share on other sites More sharing options...
PUSHER Posted February 3, 2005 Share Posted February 3, 2005 My car didnt start a while ago and then randomly started, when I checked for voltage I got 0 when the car was in accessories and I think I got like 5 volts when the car was running. God only knows whats wrong with it, but its starting and running now. Quote Link to comment Share on other sites More sharing options...
