mc Posted February 16, 2005 Share Posted February 16, 2005 I was wondering if a aftermarket in-line fuel pump could be used to pump oil[10w-30] to a low buck rear mount turbo???i'm trying to build a self contained oil system for the back mounted turbo and I am trying to eliminate running oil lines from the engine to the rear.Any suggestionson how large a resevoir would be needed as well as a safe pressure needed?????thaks for any input,mike. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted February 16, 2005 Share Posted February 16, 2005 In a word....No. You will need to find a pump that is designed for oil service. Quote Link to comment Share on other sites More sharing options...
mc Posted February 16, 2005 Author Share Posted February 16, 2005 Thanks for the fast reply,,,,,would a diesel fuel pump work??? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted February 16, 2005 Share Posted February 16, 2005 Again, I don't think that they are designed for high temp service, but maybe a diesel expert can chime in. Quote Link to comment Share on other sites More sharing options...
mc Posted February 16, 2005 Author Share Posted February 16, 2005 ok....i forgot about the heat that would be run through it. Quote Link to comment Share on other sites More sharing options...
johnc Posted February 16, 2005 Share Posted February 16, 2005 http://www.racerpartswholesale.com/mocal1.htm Quote Link to comment Share on other sites More sharing options...
mc Posted February 16, 2005 Author Share Posted February 16, 2005 thank you John! Quote Link to comment Share on other sites More sharing options...
