what kit IS THIS!!!!
Guest ahyc84
Guest JAMIE T
Use the search. Check in the turbo forum. Lots of information on it. It's old school now, but it looks awesome and runs great... At full throttle. I was going to do at one time, but I'm doing a GT-R Motor now.
Basicall, you need to pressurize the carbs using a box or plenum. You'll need a special fuel pressure regulator that raises the fuel pressure Above the boost pressure to overcome the psi of the pressurized carbs. That is for a blow thru system. Draw thru is simpler, but you can't use an intercooler.
Guest rick458
are there any issues with the MSA air dam
50-1409 and rear skirt 50-1473 and side
skirt 50-1461
fitment issues etc, funky painting characteristics etc..?
I plan on pulling off the front and rear bumpers and running these pieces
also is there anybody fabbing an inner bumper for those pieces?
