badjuju Posted February 18, 2005 Share Posted February 18, 2005 For the life of me I can't find a post (here or on zcar) on how to install a boost controller. what lines do i hook it in? Quote Link to comment Share on other sites More sharing options...
Xander Posted February 18, 2005 Share Posted February 18, 2005 http://www.hksusa.com/faq/?ID=1647 here are some installation instructions on HKS boost controllers. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted February 19, 2005 Share Posted February 19, 2005 I assume you mean an Electronic Boost Controller? As a manual boost controller goes inline on the rubber line out of the internal wastegate Yasin Quote Link to comment Share on other sites More sharing options...
HeatRaveR Posted February 19, 2005 Share Posted February 19, 2005 If you increase the boost, wouldn't that make you run lean? Or is the 20+year old ECU able to compensate to a certain point? Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted February 19, 2005 Share Posted February 19, 2005 The fuel pressure regulator is vacuum/boost sourced and will compensate for mild boost pressure changes. Quote Link to comment Share on other sites More sharing options...
badjuju Posted February 20, 2005 Author Share Posted February 20, 2005 I'm running about 7.5 psi now, instead of the 4 I was prior to the boost controller. Thanks guys. At about 3300 rpm, my injectors start wavering, you can feel the acceleration slow then speed up a couple times, but after that it's like a friggin rocket, and then at about 5k it dropps off. Also, a couple times the other night when I was driving, a plume of smoke popped out of my exhaust while I was gunning it. Any explanation? I think I'm just running way too lean and I backfired. I could feel the backfire, but as for hearing it, my stereo was on. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted February 20, 2005 Share Posted February 20, 2005 Exhuast backfire is a RICH condition Intake backfire and stuttering is a LEAN condition Quote Link to comment Share on other sites More sharing options...
