Afm swap (Cressida)
Chemicalblue
Anyone done this before? Is the cressida afm actually bigger than the turbo zx afm. I have a n/a ecu set up running a turbo motor and swapped the guts on the n/a afm into a turbo afm a long time ago. Doesn't look to difficult, just wondering if its actually 34% bigger than the turbo afm...
http://www.atlanticz.ca/zclub/techtips/afm/sizeupgrade/index.html
I have a spare Cressida AFM on my parts shelf (that I was going to retrofit on my 810, but I went to an aftermarket ECU that uses a MAP sensor instead).
It has an circular outlet with an OD of 80mm and a ID of 75mm. The inlet is rectangularly shaped, and has a 64mm x 50mm opening....
Can you tell us what a ZX turbo AFM measures?
