small block big block flywheel
All GM TQ's [i[should[/i] bolt up to all GM flexplates
I am not sure that is totally correct but can only speak from one experience in this instance. We were working on freinds 67 GT0 where his flywheel had a small bump out that kept the chevy TC from fitting up right.
i was just talkin to a guy on the phone that seems to think that a
th400 and a th350 torque converters are not quite the same.
he claims the th400 has a wider pattern.
thans the 350.
he claims the was a flex plate made to fit both th400 and th350's
but they are hard to come by.
if some one here could varify the info that would be great!!!
Yup, they are different from one piece to two piece rear seal. Yes, chevrolet did make a flexplate that only had one bolt pattern I have one of those as well as several 400sbc stock flexplates and a 400sbc flywheel. Later years had dual bolt pattern. I have a small 153 tooth sfi flexplate, dual bolt pattern that is new and never run for $70, which is what I paid for it. I installed it and then found that the converter mounting bolt "ears" stuck out past the ring gear and would hit the starter.
