Bartman Posted March 6, 2005 Share Posted March 6, 2005 I was able to get the LT1 in the engine compartment without too many problems. Here's a couple of pic's: http://home.earthlink.net/~570z/images/LT1_install2.JPG http://home.earthlink.net/~570z/images/LT1_installed.JPG I haven't "clearanced" anything yet but everything is awfully close on the passenger side of the transmission tunnel. I either need to grind the fin down around the starter and/or "clearance" the tunnel at that location. I'm very happy with how the engine sits low and back in the engine bay; it looks much better than the original engine did . Quote Link to comment Share on other sites More sharing options...
Zoldman Posted March 6, 2005 Share Posted March 6, 2005 Looking' good! Did you use the JTR crossmember spacers, or leave them out? Bill Quote Link to comment Share on other sites More sharing options...
DaleMX Posted March 6, 2005 Share Posted March 6, 2005 Looks like it was made to be there. What transmission are you using? Quote Link to comment Share on other sites More sharing options...
Bartman Posted March 7, 2005 Author Share Posted March 7, 2005 DaleMX said: Looks like it was made to be there. What transmission are you using?I agree, it looks like it was meant to be there. I've got the engine hooked up to a T-56 6-speed manual transmission. Quote Link to comment Share on other sites More sharing options...
Bartman Posted March 7, 2005 Author Share Posted March 7, 2005 Quote Looking' good! Did you use the JTR crossmember spacers' date=' or leave them out? Bill[/quote']I will be using a custom transmission mount that will bolt to the inside of the tunnel instead of bolting on to the bottom of the floor pan. Right now it's just held up by a jack . Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted March 7, 2005 Share Posted March 7, 2005 I think he's talking about the spacers that go inbetween the front crossmember (where your engine bolts up to) and the "frame". There are two half inch thick steel spacers that lower the crossmember some, dropping your engine a little into the chassis. Quote Link to comment Share on other sites More sharing options...
DaleMX Posted March 7, 2005 Share Posted March 7, 2005 Cool, I'm using a willwood 3/4" master and the T56 I have has an internal slave so I'm going to eliminate the quick disconnect and just tap the slave cylinder and run a short length of flex the go hardline to the master (like Jeromio did). I think the tunnel needs some clearance for the reverse light switch. Bang bang with a big hammer should do it. Quote Link to comment Share on other sites More sharing options...
jbc3 Posted March 7, 2005 Share Posted March 7, 2005 Bartman, Nice choice of color Mine went in for test fitting everything last week... The motor still needs to come out, apart and gone through and the headers will go out to be coated as soon as I have everything mocked up. Jody Quote Link to comment Share on other sites More sharing options...
DavyZ Posted March 7, 2005 Share Posted March 7, 2005 Bartman, There is enough space for a turbocharger in front of the engine... I appreciate the pics because I have been contemplating a future LT1 swap that will include a single large turbo at the front of the motor. The LT1 looks very "clean" in front so I think I can utilize the space there. I do have an actual turbo exhaust manifold, but I'm not sure of the flow characteristics, but mounting a turbo would be no problem. Post more pics as ou make progress, please!! Davy Quote Link to comment Share on other sites More sharing options...
Bartman Posted March 7, 2005 Author Share Posted March 7, 2005 Quote I think he's talking about the spacers that go inbetween the front crossmember (where your engine bolts up to) and the "frame". There are two half inch thick steel spacers that lower the crossmember some' date=' dropping your engine a little into the chassis.[/quote']Sorry, I misunderstood. I looked at the JTR site, and it looks like you're referring to the DAT-105 spacers. No I didn't use these spacers, but as you can see the engine sits plenty low in the engine compartment. Quote Bartman' date=' There is enough space for a turbocharger in front of the engine... I appreciate the pics because I have been contemplating a future LT1 swap that will include a single large turbo at the front of the motor. The LT1 looks very "clean" in front so I think I can utilize the space there. I do have an actual turbo exhaust manifold, but I'm not sure of the flow characteristics, but mounting a turbo would be no problem. Post more pics as ou make progress, please!! Davy[/quote']Davy, There seems to be plenty of room for a turbo, and I'm glad you like the pic's. I will keep posting my progress. Quote Bartman' date=' Nice choice of color Mine went in for test fitting everything last week... The motor still needs to come out, apart and gone through and the headers will go out to be coated as soon as I have everything mocked up. Jody[/quote']Looks good Jody. Obviously I still need to at least partially remove my motor to put in my headers and do a little "clearancing". Quote Link to comment Share on other sites More sharing options...
JustChou Posted March 7, 2005 Share Posted March 7, 2005 Hey, that looks absolutely fantastic. I'm very encouraged by your pictures - I too am swapping an LT1 into a Z. How did you go about painting the engine bay? It looks great. Quote Link to comment Share on other sites More sharing options...
Bartman Posted March 7, 2005 Author Share Posted March 7, 2005 JustChou said: Hey, that looks absolutely fantastic. I'm very encouraged by your pictures - I too am swapping an LT1 into a Z. How did you go about painting the engine bay? It looks great.Thanks Justin. I posted quite a bit of information in regards to painting my engine bay, you can look through all my posts and find lots of information and pictures. I've also posted up pic's and info at the web site in my signature below. -Bart Quote Link to comment Share on other sites More sharing options...
Tx1021 Posted March 7, 2005 Share Posted March 7, 2005 Wow that Lt-1 sure fits nice. Hopefully I can get mine to that stage pretty soon. Great work! Quote Link to comment Share on other sites More sharing options...
