Almost runs!!
Hehe...well, if it ran I wouldn't mind :) It sounds like a gigantic Harley Davidson...but, I don't have all of the vacuum lines and everything hooked up yet. I just wanted to check the fuel pump/ignition/starter wiring.
At least I know it's getting fuel, spark, and turns over.
OK...I know I said I wouldn't work on it any more tonight, but, I had to try.
I kept messing with the timing and it would run a little better each time until finally I can't adjust the timing any more due to clearance issues...however, it at least tries to fire on all 8 cylinders.
So...I'm thinking I probably just have either the distributor stabbed wrong (I had it 180 out the first try...!!!) or the plug wires off by 1.
Wow! That's all I can say. It sounds like a friggen top fueler!! :D
I'm really excited to at least have gotten this far. I still have some work left to do, but...excited beyond all belief that it's FINALLY coming together and semi-runs.
