new engine for swap canidate
some of the early sbc's had pressed on harmonic balancers, didn't work very well, so they went to the bolt addition. I've had several early cranks drilled and tapped for the bolt, no biggie. If GM went that route, then it's an easy fix. At least that way some dummy wouldn't try to tack weld it like I've seen done a time or two.
