akeizm Posted April 27, 2005 Share Posted April 27, 2005 Hi all, I've been setting up my Msns-extra with version 21u and I am trying to get my tps setup. Now I go in and use the tools to calibrate it but something isn't right. I leave the foot off the pedal and click to get the closed reading, then I put it flat to the floor (the butterfly is full open) and then get the reading for that. But when I look at the simulator the bar that represents the throttle position is only showing the tps to be anywhere between 20% and 80% (20% when closed and 80% when full open). What could be some of the problems that would cause this? Hopefully this will be the last question I will ask about msns (should run now). Thanks, Marc. Quote Link to comment Share on other sites More sharing options...
sims76 Posted April 27, 2005 Share Posted April 27, 2005 In Megatune, you need to go to TOOLS >> CALIBRATE TPS and then follow the instructions. I have a 60MM TB and have recently found that MAPDOT runs the car much much much smoother. With TPSDOT, bumps on the highway would trigger the accel enrichment. I couldn't find a happy medium with the TPSDOT. *** EDIT *** Just re-read your post and realized you alredy tried calibrating. Give MAPDOT a try. Good luck, -Sims Quote Link to comment Share on other sites More sharing options...
mobythevan Posted April 27, 2005 Share Posted April 27, 2005 I have found that you have to exit megatune and re-enter it after calibrating the TPS, then the new settings take affect and it should work correctly. It never works correctly for me after calibration until I exit and re-start megatune. let us know if that works Quote Link to comment Share on other sites More sharing options...
Forrest Posted April 27, 2005 Share Posted April 27, 2005 I asked about this on MS forums last year and as I understand it, what the TPS gauge has nothing to do with the voltage values MS looks for. If you have a problem with MS's actual behavior you will have to physically calibrate the TPS by repositioning it and checking with a volt meter. Quote Link to comment Share on other sites More sharing options...
akeizm Posted April 27, 2005 Author Share Posted April 27, 2005 Ok thanks, I'll have a look soon. Quote Link to comment Share on other sites More sharing options...
