turbo intakes...
i just spent a few hours modifying a p47 intake for my turbo engine.i cut the egr pad off and welded a square piece of aluminum in its place.non-egr manifold are scarce in cali.then ground out the mouth for bigger throttle body.then i ground out those nubs in the intake runners that the injectors hold down screws run into.then i ground the injector bosses off and bored out injector holes for o-ring injectors.then jb weld some holes back up.i got about 6 hours in this thing and it looks kind of stock.runners are 31.75mm to 32 mm at the head now.fyi-that overboost valve on stock zxt manifold should be replaced by a 1" pipe plug.stock zxt manifold has too much uneeded stuff on it.
  • 3 weeks later...
