2JZ Z engine pics
Z-Gad
ARG.. mike that sucks.. Any chance of getting ahold of the previous owner of the turbo? As for bleeding brakes.. I found it is no problem at all when using a pressure bleeder. I got one from summit and it is a LIFE saver. it hooks to the resivoir and puts positive pressure on the system as well as replaces old fluid with new and there is no way air can get in.. And you can do it all my your self with no problems..good luck man
Summit part number MVP-0101 $50.00
  • Replies 61
Turbonetics just uses the BB on the front bearing. The rear bearing is a standard journal bearing. So the seals and rear bearing are standard big shaft stuff you can get anywhere. Did the front have any play? Should be a bit less than the rear as it was BB. Was there in and out play / shot thrust bearing? If you are looking to sell as is, shoot me an email. Every turbo I have bought was someone elses problem that needed a rebuild.
