stainless steel brake lines worth it?
They take all the give out of the brake pedal. Rubber lines will swell so you can still get an extra half inch or so of pedal travel once the brakes are full on. That doesn't happen with stainless lines. Once you hit full brake pressure it is like stepping on a brick.
Whether that is better or not I don't know. Definitely more solid.
I think that price is a bit high, you can get the same basic thing from VB or MSA for about $60.00.
They are better than the stock rubber lines and as stated above the stock lines are probably 30 years old and due to be replaced.
Wheelman
