Guest scarab73 Posted June 20, 2005 Share Posted June 20, 2005 Quote Link to comment Share on other sites More sharing options...
evildky Posted June 21, 2005 Share Posted June 21, 2005 the carier inside the housing, which is the actual LSD unit can be removed bolt your gears to it and place it into the Z's long snout R200 housing, you'll then need to convert to the VLSD CV halfshafts to fully engage the LSD, I however chopped a 1/4" off one of my stock outpu stub shafts and am still running the stock U-joint axles, that being said I thought the Q used an R230? Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted June 21, 2005 Share Posted June 21, 2005 No, the Q45 uses an R200, the same unit as the Z32 NA. Quote Link to comment Share on other sites More sharing options...
Jsquared Posted June 21, 2005 Share Posted June 21, 2005 This is the only forum out of the numerous Nissan-tech-heavy forums I frequent that thinks the Q45 is an R200... I'm doubtful until I see it in the FSM. Quote Link to comment Share on other sites More sharing options...
quicker240 Posted June 21, 2005 Share Posted June 21, 2005 There is a link in here somewhere that shows the Nissan part breakbown on both the R200 VLSD and the R230.Easiest way to tell the difference is the R230 has 3 bolts across the top on the rear cover and the R200 has only 2.They both are quite similar in outward appearance unfortunately so know what your looking for. Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted June 21, 2005 Share Posted June 21, 2005 http://q45.org/techinfo.html Look in the specs under Powertrain. R200V Viscous Limited Slip. Everything on q45.org is basically out of the FSM I think. I know that the guys that run the site are extremely knowledgeable and have both owned several Q45s. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 22, 2005 Share Posted June 22, 2005 [Jsquared=quote]This is the only forum out of the numerous Nissan-tech-heavy forums I frequent that thinks the Q45 is an R200... I'm doubtful until I see it in the FSM. That is the second time I've heard someone who thinks they know Nissans say that. Have you ever actually looked at the FSM, or for that matter a 300ZXTT diff and the Q45 Diff next to one another? The ZXTT R230 is at least an INCH wider. There is a pic around here taken by Mike Kelly of my ZXTT diff next to his Q45 diff and the differance is obvious! IMHO, all other Nissan forums are for overexaggerating SR20DET's power potential. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted June 22, 2005 Share Posted June 22, 2005 im intrested in putting in the old 280z u-joint shafts (because im cheap).... how difficult is it to simply change the center but keep the shafts? do the stub axels match? Quote Link to comment Share on other sites More sharing options...
Sean73 Posted June 22, 2005 Share Posted June 22, 2005 straight out of the 1994 Q45 FSM, differential is R200V. No, it won't work with U-joint half shafts, not even close. Quote Link to comment Share on other sites More sharing options...
Corzette Posted June 23, 2005 Share Posted June 23, 2005 [Jsquared=quote']This is the only forum out of the numerous Nissan-tech-heavy forums I frequent that thinks the Q45 is an R200... I'm doubtful until I see it in the FSM. That is the second time I've heard someone who thinks they know Nissans say that. Have you ever actually looked at the FSM, or for that matter a 300ZXTT diff and the Q45 Diff next to one another? The ZXTT R230 is at least an INCH wider. There is a pic around here taken by Mike Kelly of my ZXTT diff next to his Q45 diff and the differance is obvious! IMHO, all other Nissan forums are for overexaggerating SR20DET's power potential. Jamie T I totally agree....LMAO! Its funny no one on the other forums ever post a slip with video. CZ Quote Link to comment Share on other sites More sharing options...
