zliminator Posted June 21, 2005 Share Posted June 21, 2005 I've got a door in my hobby room to experiment with. I have a solenoid intended as a trunk opener. Can't find anything here. Any links? Dan Quote Link to comment Share on other sites More sharing options...
JaysZ Posted June 22, 2005 Share Posted June 22, 2005 i think its a two-step process for doors. the solenoid would pull the latch and a door popper would push it open for you. are you talking about for shaved doors? also, trunk solenoids are usually weak in comparison.. if you want something that will last, get a 40lb + solenoid. for the trunk, you would just need the solenoid to pull the latch and the hood shocks will raise the trunk up. here are some links for options on "popping" your doors. http://www.electric-life.com/shopdisplayproducts.asp?id=141&sub=141&cat=Door+Thursters Quote Link to comment Share on other sites More sharing options...
BAlford Posted June 22, 2005 Share Posted June 22, 2005 My car has door openers but not the door popers. I bought a set but never installed then. Quote Link to comment Share on other sites More sharing options...
