Oleh Posted August 1, 2005 Share Posted August 1, 2005 I have a good deal on a 700R4 Automatic tranny out of a 89 S-10 2wd i think... Does anyone know if it will directly bolt on to a 83 280zx auto ( I think i have a T-5 and a R200 diff) Thanks... pic of the 700R4 thanks Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 1, 2005 Share Posted August 1, 2005 uhhhh....no.... Quote Link to comment Share on other sites More sharing options...
Oleh Posted August 2, 2005 Author Share Posted August 2, 2005 Why not since the input drum is 27 splines, idk about the rear though Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted August 2, 2005 Share Posted August 2, 2005 WTF I keep reading this and trying to figure out what he is asking. Will the 700r4 bolt onto what? It wont bolt onto a 2.8L Nissan motor. But if your 83 has a Small Block Chevy then you are in luck. I think Tim summed it up best. Quote Link to comment Share on other sites More sharing options...
Oleh Posted August 2, 2005 Author Share Posted August 2, 2005 ^ yeah, i should of clarified, i meant to a nissan 2.8L.... Quote Link to comment Share on other sites More sharing options...
Tim240z Posted August 2, 2005 Share Posted August 2, 2005 ^ yeah, i should of clarified, i meant to a nissan 2.8L.... uhhhh....no.... ....... Quote Link to comment Share on other sites More sharing options...
Warren Posted August 2, 2005 Share Posted August 2, 2005 If 240 Turbo (James Thagard) can put a powerglide in a 240Z, then the 700R4 should fit as well. The 700 is larger, but in the ZX, there "should" be enough room. http://forums.hybridz.org/showthread.php?t=89740&highlight=powerglide There are lots of parts you'll need, including a new shifter, a new driveshaft, a bellhousing adapter, a flexplate adapter and blank flexplate, a TV Cable assembly and you'll need to move the tranny mounts, but it more than likely CAN be done. I'm collecting all of the parts right now and only lack the, VERY expensive for what it is, bellhousing adapter at this point. I should have the 700R4 in my 82ZXT before too long. Warren Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 2, 2005 Share Posted August 2, 2005 I think the words "direct bolt on" would rule out things like bellhousing adapters. Looks like Tim gave him his answer. Quote Link to comment Share on other sites More sharing options...
Warren Posted August 2, 2005 Share Posted August 2, 2005 I DO realize that he said "directly bolt on", but keeping an open mind is always a good thing too. Just letting him know that there ARE other options if he chooses to get the 700R4 for a cheap price. Quote Link to comment Share on other sites More sharing options...
Oleh Posted August 2, 2005 Author Share Posted August 2, 2005 If 240 Turbo (James Thagard) can put a powerglide in a 240Z' date=' then the 700R4 should fit as well. The 700 is larger, but in the ZX, there "should" be enough room. http://forums.hybridz.org/showthread.php?t=89740&highlight=powerglide There are lots of parts you'll need, including a new shifter, a new driveshaft, a bellhousing adapter, a flexplate adapter and blank flexplate, a TV Cable assembly and you'll need to move the tranny mounts, but it more than likely CAN be done. I'm collecting all of the parts right now and only lack the, VERY expensive for what it is, bellhousing adapter at this point. I should have the 700R4 in my 82ZXT before too long. Warren thanks alot Warren, appretiate it... Quote Link to comment Share on other sites More sharing options...
Here comes trouble Posted August 3, 2005 Share Posted August 3, 2005 Warren.. are you fabricating a bell housing adapter or know of a source.?????? I see the 700R 4 fits a Radio Flyer Quote Link to comment Share on other sites More sharing options...
