RB26powered74zcar Posted August 3, 2005 Share Posted August 3, 2005 I saw a pic of one that had been removed w/o cutting it out, and wanted to hear from anybody that has done this. I guess its spot welded in, but I need to know how to access the welds. I don't see them from looking at it from the top side (inside the car). Can anybody help me out with this please??? thanks - joel Quote Link to comment Share on other sites More sharing options...
auxilary Posted August 3, 2005 Share Posted August 3, 2005 I cut mine out and from what I remember, it's not spot welded on. it's a solid piece that's part of the rear floordeck I don't think I see any spotwelds... maybe on the outer rim, but it doesn't look like it Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted August 3, 2005 Share Posted August 3, 2005 Grind a little around the lip from the top, you should see them then. Quote Link to comment Share on other sites More sharing options...
Vintage-TechZ Posted August 3, 2005 Share Posted August 3, 2005 Joel, They ARE spotwelded .........run some Scotchbrite ( wrapped to something flat) around the upper deck surface around the tub lip and they should begin to apear. Drill down into them slowly and in about a 30-45 minute time ....you should be able to run a putty knife blade between the seamseal and drop her out. Or just use a cut-off or Sawzall like Aux did ! The remaining lip when cut is abit stronger. Vinny Quote Link to comment Share on other sites More sharing options...
auxilary Posted August 3, 2005 Share Posted August 3, 2005 aw man! i could've bypassed the cutting? damnit! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 3, 2005 Share Posted August 3, 2005 Cutting probably took 1/2 the time of drilling and prying and then cleaning all of the seam sealer out of there if it makes you feel better. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted August 3, 2005 Author Share Posted August 3, 2005 I saw this pic in our classified adds... looks like welds Quote Link to comment Share on other sites More sharing options...
