260ZRED Posted August 7, 2005 Share Posted August 7, 2005 Would I be safe if I bolt on a n42 intake instead of the stock turbo intake?? The only thing I would lose is the emergency pop-off valve, right? The rest of the engine set-up is stock.. but I have 3 ugly block off plates on the turbo intake and the n42 looks soo nice in comparison. While the intake is off I will also modify the J-pipe to accept the 240sx TB.. Should I also put in a 'real' BOV @ the same time? Or would it be OK to run as-is for a while, without the pop-off valve??????? Thanks for any advice guys. Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted August 7, 2005 Share Posted August 7, 2005 I'm running an N42 intake from a '75 280z on my turbo motor for almost 2 years now with no... well okay, some small issues Since I don't have the cold start injector or no cold start idle valve (basically I have no 'choke') the motor idles kinda low until it warms up a bit. Not TOO low.... only a couple hundred RPM lower than usual, not enough that it chokes or lopes or anything like that, it's a smooth idle. Otherwise I'm much happier with how clean it is w/o all that junk attached. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted August 7, 2005 Share Posted August 7, 2005 I'm running an N42 intake from a '75 280z on my turbo motor for almost 2 years now with no... well okay' date=' some small issues Since I don't have the cold start injector or no cold start idle valve (basically I have no 'choke') the motor idles kinda low until it warms up a bit. Not TOO low.... only a couple hundred RPM lower than usual, not enough that it chokes or lopes or anything like that, it's a smooth idle. Otherwise I'm much happier with how clean it is w/o all that junk attached.[/quote'] Ditto. Port matched it works great. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted August 7, 2005 Share Posted August 7, 2005 also with an N42 intake manifold.. and a turbo.. you cant run the stock PCV valve.. it hits the turbo outlet... soo.. put a filter on your PCV tube coming out of the block. Quote Link to comment Share on other sites More sharing options...
akeizm Posted August 7, 2005 Share Posted August 7, 2005 You can use it you just plug up the old one, drill a hole about 50mm infront of the old hole and tap it out the same size as the pcv valve. Thats all I did to get that hooked up again. Quote Link to comment Share on other sites More sharing options...
b__sosick Posted August 7, 2005 Share Posted August 7, 2005 I have two friends that use the n42 on their turbo z's and they have minimal problems. :] Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted August 18, 2005 Share Posted August 18, 2005 I used this intake on my turbo ZX and I did what Akeizm did. Drill another hole about an inch infront of the old one and used a plug to plug the old one up.. Sorry no picture though Quote Link to comment Share on other sites More sharing options...
