slownrusty Posted August 16, 2005 Share Posted August 16, 2005 http://daemonsync.org/others/joe_edittest_1.wmv Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted August 16, 2005 Share Posted August 16, 2005 That thing is quick! Sounds sooo mean to !M! Quote Link to comment Share on other sites More sharing options...
b__sosick Posted August 16, 2005 Share Posted August 16, 2005 did his lights get brighter when he revved? sweet! Quote Link to comment Share on other sites More sharing options...
zero Posted August 16, 2005 Share Posted August 16, 2005 i think so, it seemd like they caused the lights to get brighter which in turn caused the camera to adjust. My car's lights get brighter when I rev, well at least they did the last time i drove it....two months ago. Quote Link to comment Share on other sites More sharing options...
BrandonsZ Posted August 17, 2005 Share Posted August 17, 2005 It's an Alternator-voltage thing. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted August 17, 2005 Share Posted August 17, 2005 May be the camera or possibly special effects, but if it were his lights, it might be a volt booster. Buick GN guys have been using them for years. Here's a little info from http://www.Casperselectronics.com Quote Your alternator is designed to put out a specific voltage, generally 13.8 volts. The only problem is when there's a greater demand on the electrical system, such as a WOT blast, the alternator falls a little short. The V-Plus is designed to overcome voltage taper at WOT by stepping up the alternator voltage 2.2v. at 70% throttle. Result? More power to your fuel pump and ignition system. !M! Quote Link to comment Share on other sites More sharing options...
Guest sweet350z Posted August 17, 2005 Share Posted August 17, 2005 Nice rubber Quote Link to comment Share on other sites More sharing options...
Owen Posted August 23, 2005 Share Posted August 23, 2005 Quote May be the camera or possibly special effects' date=' but if it were his lights, it might be a volt booster. Buick GN guys have been using them for years. Here's a little info from [url']www.Casperselectronics.com[/url] !M! Sounds like the Jaccuvolt (sp?), I've heard it does the same thing. Owen Quote Link to comment Share on other sites More sharing options...
